Looking at a Post 2000 ST
Uncle Phil
4 ST1100(s)
002064
698
Any ST1100 ABSII (96 or later) with less than 100,000 miles that has had not been crashed, has not been sitting, and has had the oil changed regularly would probably be fine. If it's been sitting, you'd have to probably clean the idle jets - which it not that big a deal.
No VA, DC
Thanks very much. What price range I should be planning to pay? Of course a general idea.
No VA, DC
I really liked your website. It's just awesome. THUMBS UP!
Grand Haven MI
2004 ST1300
000255
8800
I picked up a 2000 in late April with a Sargent seat & a Laminar Lip screen for around 3K. It had 39K miles.
Its now ready for an oil change......
Dale_I
Incorrigible Idealist
Spokane, WA
08 FJR1300/01 ST1100
001754
5341
Keep your eye out. You can get them at $4k to $5k fairly easily. But you see a deal every now and then where you can get decent miles in the $3k and less.
Ron
Orlando
ST1100s
2432
1996 was the dividing year. Different alternator, earlier had 28 amps, '96 + has 40 amps. Non ABS were all the same except the 40 amper after '96. All ABS II (from '96 up) are the same except for color.
jfheath
John Heath
Ilkley, W Yorkshire, UK
2013 ST1300 A9
000679
2570
Good luck with the search. Latest versions here in the UK were 2002.
Go for ABS - you'll see the pulsar rings on the front and rear wheels, but check that the ABS lights go on when the ignition is turned on (so that you know the bulbs are working) and that they go out when the bike starts rolling forward. This proves that the ABS has armed itself and that the sensors and modulators are working. Ditto the Traction Control light if it has it. They can be expensive to repair.
OEM exhaust system is not stainless steel, and can corrode badly. In the UK I would get through silencers in around 35000 miles.
Take a look here. When I was selling my 2000 ST1100 ABS/TCS/CBS model, I put some stuff on my website pointing out what would need doing typically for a 2nd hand bike, and what I had done. Look under the Selling link in the right hand menu. Just trying to drum up interest at the time. I kept it on the site for info. It sold in 2009 for £3000 with 70K on the clock. Subsequently it was knicked and then found and cosmetically restored to original spec. It is still on the road.
