Help Identifying a part
South Central PA above the Mason Dixon line
2012 ST1300
I pulled the rear wheel on my and I removed the bolt that has the pin that secures into the yoke. It has a short round boot to keep the grease. When I realized my mistake I looked at a parts guide to make sure everything is where it need to be but I cannot find this part
[FONT=&quot]BOOT, PIN BUSH (NISSIN)[/FONT]
[FONT=&quot][/FONT]
[FONT=&quot]45132-166-016
Can anybody help where to look on my caliper?
Walt[/FONT]
The Dan
The Dude Abides
Vendor
Watertown SD
2009 ST1300 ABS
7982
It's installed in the caliper and in turn that slips over the pin on the mounting plate " Yoke ".
jfheath
John Heath
Ilkley, W Yorkshire, UK
2013 ST1300 A9
000679
2570
That particular boot pushes all the way into the hole so that the end emerges at the other side. So when it is in the caliper, you can see part of the boot emerging at each end.
Double check before inserting it into the hole that you have the opening at the correct side !! The slider pin should be lubricated lightly with silicon grease. Don't use too much as it can create an air lock which can compress and cause the caliper to push the brake pads against the disc rotor - result - hot brakes.
