Handlebar cowling
Oxon
So my pan came with risers that I don't need. And no covers...
Which covers do I need as there seems to be three types on eBay....
finger lakes ny
1999 ST1100
7959
That looks like an early 1100. It would use the three piece cover, as opposed to the two piece of the later years.
Not sure what all those metal straps are. Maybe the 'framework/brackets' of the cover. If that's the case, just take em off.
First thing I did to my 1100's was to remove that big hunk of plastic cover. There's enough plastic on the rest of the bike.
Oxon
No it doesn't appear so. That I was told was the bracket for the plastics.....??
Auckland, New Zealand
8901
I have a 1990 ST and that is the same as what you have in the photo. As stated, there are three plastic pieces that comprise the bar covers.
The large rectangular plate under the bars is correct, the four small brackets bolted onto that are not stock parts. The stock left and right parts bolt into those holes directly, then the centre part drops in, uses a hook over the wire that runs in front of the ignition, presses into the plastic socket, and then connects to the left and right parts with screws.
Grand Junction, Colo.
92 ST1100
+1 to Dean's statement. IMO, that cover is not only fugly and distracts from rest of bike, but if tried to be used with risers, good luck getting key into ignition;).
They look like they were added to hold some gear like a radio or something. Had it been a police bike there are a few radio control heads that would fit in that area.
