Clever Ways To Tell If Your Linked Brakes Are Working Properly
New York
The first is put the bike on the centerstand with the transmission in neutral and see if the wheel spins freely. This probably ought to be done before every ride just like checking the tire pressure and first thing in the morning while on trips.
The second is to get one of those $25 infrared temperature gauges from Harbor Freight and monitor the temp of the calipers. Get an idea of the rear caliper temperature under normal use and when riding on the freeway with little or no use of the brakes. Any serious rise in caliper temperature :eek: is cause for further investigation.
BakerBoy
It's all small stuff.
Golden, Colorado
1408
Another way: Away from the distraction of other vehicles, come to a stop and hold the brake levers until all bike, body, and suspension movement settles. Then release the brake levers and feel the suspension reposition itself. If the SMC is working properly, the bike suspension will subtly reposition itself as you release the levers.
Do the $25 HF IR gauges have an On/Off switch? I got a $10 gauge from Amazon that doesn't have a hardware switch. It just goes into a 'standby' mode that kills it's 9V battery in a week or two.
The compartment is too small to disconnect the battery and leave it inside. It's just enough of an inconvenience to remove/replace the battery that I'd consider a higher-end cheapie.
A simple call to the white courtesy :call:
Check this out.... Thermoworks
Thanks for the link. HF has three at $28. They aren't the cool yellow like mine or the Thermoworks but the latter is $49 and that's more high-end than I need.
I'll check out the HF thermometers. For the amount of use I'll get they should be fine.
EASt
Streuselkuchen
Minnesota
S1000XR
Always with the elegant solution.
For me, I chased a brake problem on my ST for almost 7 years. I always suspected the LBS had a gremlin somewhere:
When breaking - particularly in slow traffic - one of the pistons on the rear caliper would hold, hold, hold... clunk. I removed and cleaned the caliper twice in those years, and never figured it out. It bugged me.
So, by either of the test methods... mine failed! :rolleyes:
New York
Sign up for thier coupons delivered by mail to your house. Or put their online couponds on your iphone and show it to the checkout person. 25% off 9/4/17.
My HF thermometer is not sold anymore and its over five years old and is used so much its on its second set of batteries.
Thanks for the pro tip. I've gone through three batteries in five months.
