Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: 2004 st 1300 oil leak at clutch slave
  1. #1
    goboyboat Goboyboat's Avatar
    04 st 1300
    Join Date
    Nov 2016
    Richmond VA
    Posts
    2
    My Gallery
    Hello everyone my question is the seal that keeps the oil in the engine How difficult is that to remove ?
    Thanks in advance for replies
  2. #2
    Mikedo's Avatar
    2003 ST1300A
    Join Date
    Jul 2013
    Chatham, Ontario, Canada
    Posts
    163
    Tip Overs
    1
    My Gallery
    Re: 2004 st 1300 oil leak at clutch slave
    If you want to get no better at something...keep not doing it.
  3. #3
    Bobb's Avatar
    '04 BLUE ST13
    Join Date
    Jul 2017
    Brimfield, Ma.
    Posts
    54
    My Gallery
    Reviving this thread. I think the OP wants to change the oil seal that keeps the "motor oil" sealed, and is located in the block itself behind the slave. Mine is weeping here as well, waiting for parts as we speak. I have a slight drool that comes out of the small "weep hole" on the right bottom side of the slave......clutch works fine, no loss of fluid, but looks like motor oil. I ordered the complete slave and this extra seal. Anyone change that one? If so how many skinned knuckles do we have?
  4. #4
    stgolfer's Avatar
    2003 ST1300 ABS
    Join Date
    Sep 2007
    Gainesville, Florida
    Posts
    1,630
    Tip Overs
    1
    My Gallery
    I replaced the entire slave a couple years ago, and now I suspect my oil leak is coming from there. I'll find out when I pull the bike apart next.
    Replacing the slave is a pain to get to, but not really all that hard. I'll be following this thread, as well.
    Bill
    STOC Event Attendee, IBA#48639 - SS1000, SS2000, BunBurner Gold
    '03 Honda ST1300ABS '00 Honda GL1500SE Goldwing 25th Anniv. Ed.
  5. #5
    Site Supporter MaxPete's Avatar
    2007 ST1300 ABS
    Join Date
    Oct 2015
    Windsor, Canada
    Posts
    1,186
    Tip Overs
    1
    My Gallery
    Me too - clutch slave issues are sort of my "thang"...
    The harder I work, the luckier I get.
  6. #6
    Bobb's Avatar
    '04 BLUE ST13
    Join Date
    Jul 2017
    Brimfield, Ma.
    Posts
    54
    My Gallery
    Ok guys, just completed the slave replacement. Wasn’t all that difficult and it took about 2 hours. I did not replace the seal in the block because it did not look like it was leaking. I didn’t want to create a new problem replacing it. The old slave seal looked quite “knackered”. Bled it all and it seems nice and smooth.
    Attached Thumbnails Attached Thumbnails EFF205DC-4D2A-42CA-B2C5-9D090AABD663.jpg
  7. The Following User Likes This Post:
  8. #7
    2007 ST1300 ABS
    Join Date
    Oct 2015
    Windsor, Canada
    Posts
    1,186
    Tip Overs
    1
    My Gallery
    Good work Bobb - that CSC certainly looks like mine did (knackered - just as you say).
    One bit of comfort - I researched the entire ST1300 clutch slave cylinder R&R job quite extensively and in all of those enquiries- not one instance of that seal in the engine block was mentioned.
    Best wishes!
    Pete
  9. #8
    Play it makes life fun STGUY's Avatar
    2007 ST1300A
    Join Date
    Jan 2016
    Byron, IL
    Posts
    210
    My Gallery
    Well, I believe I got it to do. Thank goodness for everyone posting their experiences.
    Sent from my SM-G920V using Tapatalk
  10. The Following User Likes This Post:
  11. #9
    Bobb's Avatar
    '04 BLUE ST13
    Join Date
    Jul 2017
    Brimfield, Ma.
    Posts
    54
    My Gallery
    Quote Originally Posted by STGUY View Post
    My thanks as well. If it weren't for such a good write up that "mikedo" linked me to {thanks Pete!!}, not so sure that it could be done in this manner...or in the time frame it actually took. Couple of problem areas {for me anyway}.....
    1. The old gasket removal. Like others have said...it is a pain. Period. Be very careful around the oil cooler hose. They do make a spray on gasket remover that really does work, but I didn't have access to it at this point in time, nor did I want to go to the store to get some. Hindsight....I "should have".
    2. Third bolt access adjacent to the oil filter. For that bolt, {once it is loosened} you really need small hands and long fingers to unscrew / screw it in.
    3. On the 3 bolts that hold the slave on.....I used a 1/4" drive ratchet / socket and access to all three bolts was VERY easy. The article said to use wrenches. Personal preference here.....Edit.....correction. Brain fart....not enough coffee. Pete used the ratchet here as well.
    4. I used a headlamp around my noggin for an excellent, bright view of the problem area.
    5. I did not remove the speed sensor as it was not at all in the way.
    6. Have a lot of towels / rags as you work.
  12. The Following User Likes This Post:
  13. #10
    stgolfer's Avatar
    2003 ST1300 ABS
    Join Date
    Sep 2007
    Posts
    1,630
    Tip Overs
    1
    My Gallery
    I thought you were leaking motor oil? How is replacing the slave, without replacing the engine block seal, going to help? Is your leak somewhere else?
+ New Posts
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
