DavidR8
- Joined
- May 31, 2017
- Messages
- 1,221
- Location
- Vancouver Island, British Columbia
- Bike
- 2013 BMW R1200RT
- STOC #
- 8968
After too few km's on our new to us 2005 I have a few questions:
- Aside from starting, what should I expect for start-up behaviour?
This morning it was 19 deg C, bike started fine but seemed like it wanted to stall as the rpms stayed under 1000. I gently took it to 2000 rpm and heard a slight 'thunk' and then the idle seemed to stay a bit higher.
- On the ride home from previous owners house I noticed the dreaded heat. Only three bars on the dash, outside temp was about 25 deg C.
The bike came with a K&N air filter. At the risk of starting an air filter war, I wonder if the increased airflow is causing it to run a bit lean thus hotter.
I read in a post by @igofar that he sees K&N filters on bikes that run hot. I'm not interested in increased performance so am happy to go to a stock filter if it results in cooler running.
- Lastly, is there a factory service manual available for the ST1300?
