DavidR8
- Joined
- May 31, 2017
- Messages
- 1,221
- Location
- Vancouver Island, British Columbia
- Bike
- 2013 BMW R1200RT
- STOC #
- 8968
Nope I sure don't!I guess you don't skip leg day.
That's a good point ST.Another -1 for the grass idea. The tip over wing limits the distance between the handlebars and the bike. Trying this on grass might allow the tip over bar or even the handlebar to be pressed into the ground allowing it to lie flatter than on pavement.
Between slipping on the grass and having the bike's handlebars lower than practical this could be even tougher than the real thing.
The ST may be lighter than a 'Wing but the center of gravity is higher and I believe the tip-over lean is greater. I had to pick mine up from a slight decline which made it rougher still. It was in gear but I also use the Pendell Parking Brake so there was zero lash to worry about.
If your quads are in good shape this may be easy but I hope never to have to do it again. And my back was a sore for a couple of days as well.
Your second example is what very nearly did me in on Friday night.I've had 2 tipovers and I'll share how they happened so maybe someone can avoid a similar pitfall...
First one: I stopped on a sloping road where the slope dropped off to my left. I was able to get a toe on the ground and balance briefly until I told my passenger to put her left foot down while forgetting that she can't reach the ground without leaning over. She tried to do as I asked and the extra weight on the left side took us down.
Lesson: don't park where you won't have solid footing.
Second one: Making a u-turn on an incline. The bike ran out of momentum and I couldn't get on the gas fast enough to prevent a tipover to the inside.
Lesson: practice friction braking so speed control is not only governed by throttle.
Okay, my suggestion was only to practice before need; not necessarily on grass.Another -1 for the grass idea.
Yes, Get some help.Thanks for your post ST460,
Do you have any tips to share on picking up the ST?
