So I took a chance on a versa cruise that "fits most Hondas" although I was concerned about clearance . Well I managed to get enough clearance for the clamp that attaches to the handlebar but when I went to tighten down the housing I realized there is a pin on the lower side that fits into a hole in the handlebar, securing the housing at the proper location.
But to make room for the versa cruise I moved the housing about 1/16 inch. Do other bikes have this location pin and is it
really needed? I thought of drilling a new hole, or removing the position pin. Right now I have it partially attached and it seems to work just fine, but not a good permanent situation. Other than returning the versa cruise, I just want thoughts on drilling a new hole, removing the pin, or leaving it as is. It really works fine as is but the housing does not have a good seal and will allow moisture to get inside.
Thoughts?
Thoughts?
