Why not do what I did? All you need to do is remove the RH side cover, add a couple of wires from the remote control (the hot wire fused) and connect the fused wire to the switched terminal that goes to the starter, ground the other wire and your in like Flint. You might be able to do it like UP and solder the wires directly to the switch contacts after determining which wire to solder to which contact, or do it like me and connect them to the clips with the contacts for the original battery and using a tie wrap to hold the PB depressed. Obviously, UP has the best solution if you have the skill and dexterity to do what he did in close quarters. I'm not sure if I could do that with confidence, I would have to see it first.This is my plan if I ever get round to it. I do have the NO PB.
