737Captain
Heavy Equipment Operator
PMs cleaered outI tried to send you a PM Tony but apparently your mailbox is full. You'll have to delete some items before I can send it.
Thanks Skip
It is plug and play, You may need to do the procedure to clear codes once it is connected. Before you start the engine Check that the FI light cycles on for a few seconds when the key is turned on. You should hear the fuel pump run for a few seconds as well. Once the engine starts the FI light should be off and stay off unless there is some other problem in the wiring or bad sensor. If the light stays go for a good test ride.Well I broke down and bought a new ECM whil3 they are still on sale. Does anyone know if they come programmed so it’s just plug and play or will it need mapping.
Good luck Tony! I sincerely hope it's your solution.Well I broke down and bought a new ECM whil3 they are still on sale. Does anyone know if they come programmed so it’s just plug and play or will it need mapping.
Take this shortcut:Go to Igofar Reviews and read post #524 before you start spending money on a new ECM.
