Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: Compression Test & the Starter Motor
  1. #1
    glen's Avatar
    97 ST1100
    Join Date
    Aug 2017
    Kansas City MO
    Posts
    8
    Tip Overs
    3
    My Gallery
    Hey all,
    I tried to run an engine compression test on my '97 ST1100 as per the instructions in the Clymer service manual. According to the book, I should be able to crank the engine with the starter motor while the engine stop switch is OFF. However, my starter motor does nothing without the engine stop switch engaged. Any ideas what I'm doing wrong, here?
  2. #2
    Brant's Avatar
    92 ST1100
    Join Date
    May 2007
    Grand Junction, Colo.
    Posts
    1,516
    My Gallery
    Re: Compression Test & the Starter Motor
    The STOP/Run switch electricly completes the running circuit, and likely completes the starting circuit also.
    1992 ST1100
    1981 Yamaha XS Venturer 1100
  3. #3
    SMSW's Avatar
    Join Date
    Sep 2013
    cleveland
    Posts
    2,702
    My Gallery
    You will have to do the test with the STOP switch in the run position. Make sure all plug wires are away from your hands - the shock can be surprising.
  4. #4
    Bush's Avatar
    1996 ST1100
    Join Date
    Jun 2006
    British Columbia
    Posts
    1,950
    My Gallery
    All those plug wires should also be grounded to the engine while turning the engine over.
  5. #5
    240Robert ST Gui's Avatar
    Join Date
    Sep 2011
    Posts
    5,136
    My Gallery
    Quote Originally Posted by glen View Post
    I'm guessing that's an error in the Clymer manual. This was possible in some older Hondas I had.
    Honda changed that maybe so that some people wouldn't kill the battery trying to start the bike with the switch inadvertently left in the Off position. I don't know.
    I do know I feel a little less stupid when hitting the starter and nothing happens because I made the same mistake. Harder for the casual observer to note my rookie mistake.
    Don't tell me what I know. Tell me what I don't know.
    Ride safe, ride often.
  6. #6
    Oldbikefixr's Avatar
    91 ST1100/06 ST1300
    Join Date
    Aug 2015
    Fort Worth, Texas
    Posts
    2,957
    Tip Overs
    1
    My Gallery
    I have a 1991 1100. It WILL crank with the kill switch engaged. On the center stand, side stand either up or down...still cranks. With the bike on the side stand, it will not crank regardless of the position of the kill switch.
  7. #7
    Bush's Avatar
    1996 ST1100
    Join Date
    Jun 2006
    British Columbia
    Posts
    1,950
    My Gallery
    Not sure what year it changed - my '95 would not crank with the switch off, but early models did allow this. Think I remember reading about it in the old ST1100 Newsletters.
  8. #8
    Site Supporter Don B's Avatar
    Join Date
    Oct 2007
    Alief, TX, USA
    Posts
    1,926
    Tip Overs
    1
    My Gallery
    Quote Originally Posted by Bush View Post
    How about simply unplugging the coil primary wires and insuring they won't touch anything that can ground them?
    The Older I Get ... The Better I Was
    '03 ST1300A (The one with the faST black wheels)
  9. #9
    91 ST1100/06 ST1300
    Join Date
    Aug 2015
    Fort Worth, Texas
    Posts
    2,957
    Tip Overs
    1
    My Gallery
    Quote Originally Posted by Don B View Post
    That's what I do whenever I perform a compression test. Makes sense to check the spark at the same time.
  10. #10
    Bush's Avatar
    1996 ST1100
    Join Date
    Jun 2006
    British Columbia
    Posts
    1,950
    My Gallery
    Sounds like more work to me. Just leave the plugs in the leads and ground the plugs on the engine.
+ New Posts
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
