My 2002 ST1300A ABS
Holmfirth
ST1300 A2
In this thread I am detailing my bike as purchased in October 2017. This thread will be updated as I identify the non-standard features of the bike, also as I complete work on the bike such as inspection, maintenance, and further modification.
All feedback welcome :)
Sent from my E6653 using Tapatalk
Andrew_Lumb
Holmfirth
ST1300 A2
Comes with...
Honda top box w/ back and arm rests
Gear position indicator
Indicator green lamp repeaters
Indicator amber lamp repeaters
Andrew_Lumb
Holmfirth
ST1300 A2
Heated grips
Givi windscreen
What I assume are wind deflectors down the side fairings and around the mirror housings
Andrew_Lumb
Holmfirth
ST1300 A2
LED sidelight bulbs (front only)
HID headlight bulbs (dipped and main)
12v socket (1x Honda at front of storage compartment, 1x extra at rear of compartment)
A couple of holes and unknown wire in locked storage compartment
Andrew_Lumb
Holmfirth
ST1300 A2
Some holes in the pannier and a sticker, presumably an intercom which has since been removed from the bike.
Virginia
2004 Honda ST1300ABS
8954
Is that an 02, or 03. .I thought 2003 was the 1st year for the ST1300?
Sent from my SM-G955U using Tapatalk
Those are indeed the factory Fairing and Mirror Deflector sets. Out of production they are highly sought after.
A very nice looking bike and generously farkled Andrew. Were I lucky enough to score a Honda top box I wouldn't rest until I got the factory LED spoiler. For me it's the whole reason for the top box! :grin:
Scored a used set by sheer dumb luck.
When you're lucky you don't have to be good. And I'll still say 'Well done!'
And not to put too fine a point on it but the Fairing and Mirror Deflector sets are two sets not one.
So double well done!! <— worthy of an extra exclamation point.
Andrew_Lumb
Holmfirth
ST1300 A2
The lower fairing wind deflectors get in my way, I'm quite long legged. Some of that might be technique, or seat height (not experimented with that yet), but they are quite sharp!
Only thing I will do in the short term is play with the seat and fit the sat nav, everything else will remain while I get used to the bike and put a few miles on it for the rest of the year. Then I'll decide what I'm going to change over the winter.
Thanks for the comments :)
jfheath
John Heath
Ilkley, W Yorkshire, UK
2013 ST1300 A9
000679
2570
Hi Andrew
Since the previous owner had all sorts of stuff on there, I'd take a look at the connection that remain to the battery. I've seen all sorts of spaghetti strapped onto the +ve battery post, unsecured and unprotected. Pay particular attention to any additional wire going from the +ve terminal to the first inline fuse. If it can move around and rub then at some time it will wear through to the copper. With no fuse at that point to protect it, it will leave you stranded or singed !
If you fancy a ride over in this direction some time I'd be happy to cast an experienced eye over it.
Andrew_Lumb
Holmfirth
ST1300 A2
Hi Andrew
That sounds like a good idea John, I definitely don't want to get singed!
