Headlight Assembly - Aiming?
Spain
I've brought over to Spain a 2006 Honda ST1300A from the UK. The headlights need to vonform to Spanish regs i.e. beam points to the right. Can the headlights be adjusted or do I need to buy a complete new assembly made for europe? In terms of fitting, are all the ST1300s headlights the same. Does anyone have a European standard HEADLIGHT ASSEMBLY for sale? Any help will be much appreciated.
002760
This is from another member on the site and probably a U.S. spec so assuming they are similar.
002760
Thanks Mellow.
What lights are moved by the the two centre vertical adjustments?
(Pardon my ignorance)
Left and Right individually.
Camarillo, Ca
2006 ST1300A
002552
Notice that the top tab is not straight up but is offset. This makes the headlight assembly universal so that it can be used in left hand or right hand driving Countrys. Most motorcycles are like that. The ST1300 headlight is designed to create a flat beam with no up tilt on either side. So you are good to go. if anything you might have to adjust the two outer (big) knobs to swing the hot spot a little to the right. Do the adjustment using the high beam since it is more focused and you can see a defined spot. then check the low beam.....
Lorca, Murcia
ST1300A black
Hi EricJ. I have a 2004 ST1300A that I gave bought over from the UK and hoping to matriculate. Did you eventually get a resolution to this problem?I would be grateful for any advice you could offer.
Regards
