Yes, they do need to be pried off the boots, but be careful not to pry on any linkages. Getting them back on, with new boots, is relatively easy if you smear a bit of silicone grease on the new boots, then get one bank of the carbs lined up with the boots and push the whole unit straight down. They should pop right on.Pic shown using a broom handle to assist pulling the carbs out of boots.
EDIT: Make sure you note the position of the carb boot clamps before removal, as they will interfere with the choke linkage movement if they are wrongly positioned.
