Cooling...rubber mat under carbs.
Whitewater,Wisconsin
98 ST 1100
How important is the rubber mat under the carbs? I found it lying on the floor after installing the carbs. Do I really need to pull the carbs?
Northumberland UK
VStrom 650
How hot is it in Wisconsin?
You will probably notice more heat from the engine and I presume one reason it is there is to stop/reduce fuel vapourising.
It's your call?
Have I spelled vapourising wrong?
Upt'North.
British Columbia
2021 RE Meteor 350
That's a tough break, but Honda engineers thought it was important enough to include it in the design, so . . . .
finger lakes ny
1999 ST1100
7959
I think I remember doing that. Carbs came off again.
Also cut another mat, for possible use in the future, out of some rubber roofing material. Not sure if that's an appropriate type of rubber for around a hot engine though.
Fort Worth, Texas
91 ST1100/06 ST1300
It's your call?
Upt'North. <<<<
You UK types use entirely too many vowels in your words.
West Michigan
'98 ST1100
8470
Very Important , IMHO. Time to pull those carbs (again). It's easy after the first time. Get a longggggg screwdriver to reach the screws on the carb "rubber" clamps. It won't take long at all. Don't feel too bad.
West Michigan
'98 ST1100
8470
Good move!! If I was you and I didn't replace the mat, it would worry the heck out of me. Gotta treat these '98 ST1100's with TLC.
It's your call?
Upt'North. <<<<
And not enough ZZZ's
