Low Idle Stalling
Melrose MA
When cold starting my 2005 it starts right up and idles well above 1K until it warms up. As it warms up the idle begins to drop and goes well below 1K and will stall out unless I keep the throttle up. Once it gets its three bars temp it is fine. Getting to that point it is having difficulty at idle. I can drive it but until it warms up completely it will stall because of such low idle. Is there a sensor that is failing possibly?
DavidR8
2013 BMW R1200RT
8968
I suggest that 5-way T needs cleaning.
DavidR8
2013 BMW R1200RT
8968
The 5-way T is a vacuum connection between the four throttle bodies and the MAP sensor. Four vacuum lines to the throttle bodies and one to the MAP sensor makes five.
I cleaned mine after after some rough idling and the FI light flashing the code for the MAP sensor. While this seems like a big deal, it was a really easy job. Probably took less than 2 hrs.
Have a look here for my first journey into the mechanicals of my ST1300: https://www.st-owners.com/forums/showthread.php?160473-FI-light-flashing&p=2038153&viewfull=1#post2038153
Blrfl
Natural Rider Enhancement
Northern Virginia
Fast Blue One
4837
While you're in there, also make sure the linkages that connect the wax engine to the starter valves are clean and move freely.
--Mark
Carter
Melrose MA
Would you know what the inner diameter of the hoses is? i should have some on hand in case i need them.
