Light switch issue?
CT USA
07 ST1300
This morning..cold cold morning. I was warming the bike while donning my gear. Noticed my headlights were off. All other light's normal. Fiddled with the dimmer switch a bit and they started working. What's this about I wonder?
Toronto, Canada
2001 ST1100
Had the same problem when it got cold .... tried some contact cleaner .... I think its the ignition switch ??
Gord
wjbertrand
Ventura Highway
Ventura, CA
Squirt out both the high/low and starter button switches with some plastic safe contact cleaner. Probably not the ignition switch itself if everything else was working.
JimGregory
CT USA
07 ST1300
On the way home in the dark it acted up again. Switch the high/low beams a bit and they work again. Not fun when the lights go out in the dark. Haven't tried the starter button.
So what is a plastic safe contact cleaner? I have some stuff here I think. I must start to disassemble all switches!
JimGregory
CT USA
07 ST1300
pulled switches apart and hosed down with Deoxit. It removed all mushiness in everything including turn signals. Slow drying though and I may need a touch of silicone spray to re-lube things.
I used deoxit because I had it. CRC may work better. Surely cheaper.
A long term fix is to take the switches apart and clean the contacts then reapply a dielectric grease. The switches are precisely made and no springs or balls fly out as each little screw is removed. Honestly I think the switches will last forever in these things if cleaned and lubed every so often.
JimGregory
CT USA
07 ST1300
Seems to me that the actual contacts were OK but the lubrication in the switches thickened in the cold resulting in sluggish operation. I will today work some silicone lube into them to replace the flushed out hardened lube.
I can now feel all the detents and such that were gone before flushing. My turn signal switch is now crisp and easy to turn off. Before, shutting them off was difficult and hit or miss.
I am sure there is more then 1 thing that goes wrong with these depending on the situation, and I agree a disassemble and thorough clean and relube is likely best.
Are your headlights operating normally now?
JimGregory
CT USA
07 ST1300
I hope so. Gonna be dark on the ride home.
This morning after the squirting I could not get them to fail. However it's about 30f warmer then yesterday morning.
True test is riding at night in the very cold. Can't wait!
Fingers crossed for ya! Cleaning out some of the sludge should be a good start. My ST buddy had the same problem and to get to work through the week he just squirted some contact cleaner into the open switch housing. He was heartened when I told him I had it on good authority that no small bits would fly out when he opened it. That fixed his problem.
