ST1300 test harness
DavidR8
2013 BMW R1200RT
8968
I received my service manual yesterday so am gradually turning its pages.
On the forum I've read that the test harness is not available.
From what I can tell isn't it made of standard 26 pin connectors?
With the right skills wouldn't it be a relatively simple thing to make a test harness?
ST_Jim
In the Hotel California...
Simi Valley, CA
2004 ST1300ABS
4829
Yes, but "standard" doesn't mean readily available in the US. Figure out the manufacturer, a distributor that will sell small quantities, P/N's for the male & female, pins, and maybe a crimp tool. Or maybe fab a PCB to connect the two and fan the signals out.
Yes, conceptually it's not that difficult to fabricate. But part of the issue is understanding what the ECM is actually supposed to do, or not do. The actually knowledge is likely not documented properly anywhere, and certainly not available here in the US. There have been many so called experts that have given up on the ST ECM.
West Michigan
'98 ST1100
8470
+1 to the above.
If you could get the connectors & pins, it would be relatively easy to construct - nothing magic about it. Sounds like a good winter project. It could then be loaned to ST1300 Owners on this Forum.
SO ...... Is there a manufacturers name on the connectors ??
DavidR8
DavidR8
2013 BMW R1200RT
8968
The reason I thought that it would be interesting to have a test harness is because it would allow a person to test every pin for the expected readings while the bike is running.
Or am I completely missing the point of it?
ST_Jim
Simi Valley, CA
2004 ST1300ABS
4829
Experts - I was thinking of "Ivan's Fuel Cut Eliminator" for the ST1300, that malfunctioned on some ST1300's. Ivan gave up on it.
I PM'd Jeff this thread link, to see if he recognizes those connectors. I don't recall myself.
wjbertrand
Ventura Highway
Ventura, CA
Not sure, they could be the correct ones. What I can see if the back side looks like there's some kind of cover? The OEM have no covers, just the wires exiting directly. The pre-‘08 models do have two large rectangular connectors like that. Same size different colors. Having repaired a couple connectors with some plug assemblies (on the replacement main harness I bought) from Eastern Beaver, I found there are many subtle differences in otherwise similar appearing connectors.
I could take a photo of the plugs on my old harness if it has value.
Blrfl
Natural Rider Enhancement
Northern Virginia
Fast Blue One
4837
To make matters even more fun, the ECM change in 2008 to 33-pin connectors. . I don't have a handle on the 26-pin connectors they used from 2002-2007. If Cycleterminal has a source for the females, they can probably tell you where to get the males.
I haven't had a need to try this myself, but it should also be possible to make contact with the pins in the harness connector by slipping a needle probe in alongside the wire. (Last time I brought this up, somebody pitched a fit about piercing the insulation. I'm not talking about that.)
--Mark
Vernon BC Canada
09 ST1300
That is exactly the way it's done in automotive testing. Special test probes (similar to a needle but blunt ended and flexible, with insulated outer portion and a means to plug test leads into). This is referred to as "back probing" and the probe is simply slipped in between the rubber seal and the wires' insulation to make contact with the terminal. Done with care it does not harm the sealing integrity of the connector, and wire insulation is not pierced. This is all you need as there really is never a need to have all the pins available in a break-out box all at once - you are usually going after maybe 1 or 2 circuits at any given time, and you really don't very often have the need for a "known good" signal to compare to because when you get into this type of testing, you have already studied the schematic and have a solid understanding of circuit design and how it functions, and you already know what type of signal you are going to see, or not see.
thekaz
haz gone feral
canadian west coast
Break out tools were essential to mechanics before OBD & OBDII ..... It was a great and easy to tell if your ECM was recieving a bad signal or was proccessing a correct signal in the wrong way.
Now its just hook up your scanner and watch the signals. GOD I wish all bikes had OBDII :(
thekaz
haz gone feral
canadian west coast
Ivans only mistake was thinking he could change the fuel map in one specific column on a closed loop system without opening the system or activating limp.
Don't get me wrong it can be done but you will loose "something" be it fuel economy or torque curve etc .... Changing the original map altogether is the best way but I know of no one who has even attempted to compile the ST1300 ECU fuel data or hack the ECU. For those stuck with the bizarrely termed "fuel cut" just go buy a non-USA spec ECU :rolleyes:
