Lifting the '02 ST1100 with a Craftsman MC lift
CT
2002 ST1100
The lift is new and I haven't tried lift the ST1100 with it yet. Do I need to fabricate some kind of a special board so the bike sit's right on the 2 rail that lift the bike?
I have the direction to make a lift base board for the ST1300 but I'm not sure if it will work on the ST1100.
kiltman
Stratford, Ontario Canada
2002,ST1100ABS
8826
Re: Lefting the '02 ST1100 with a Craftsman MC lift
I use a 3/4” thick piece of plywood that measures 12”x24” that sits on the lift. Under the center stand I have a 1”x1”x12” board attached to the plywood and a 2”x4”x5” block that sits under the oil pan by the drain plug and fits between the exhaust pipes. That is what I use on my Bulldog lift which is similar to the craftsman
Dan T
CT
2002 ST1100
Thanks Kiltman. I have a sketch Ken Hill put together for a ST1300 but I don't know if it's good for a ST1100.
