https://www.harborfreight.com/brake-fluid-bleeder-92924.html
If you have a compressor, this thing is the bomb. Made for four wheelers but makes bleeding brake lines much easier and less messy. This thing runs off compressed air utilizing the venturi effect which creates a constant vacuum in the receptacle. The receptacle is large enough to accept all of the old brake fluid from a full sized pickup. All hoses and fittings are included, but you will need a male quick connect to connect to your air line.
I have been using a Mighty Vac for years, but I think I am going to use this thing from now on.
