2002 ST1100 with ABS/TC - Handle Bar Options???
CT
2002 ST1100
As you guys know I'm new to the ST world.
My new to me 02 ST1100 with ABS/TC has 1" raisers for the handle bars. I'd like the bars to be 1" higher and 1 1/2" closer to me.
I have not found any bar raisers that will put the bars 2" higher than stock and 1 1/2" closer to me.
So my focus is know on different handle bars.
Has anyone found a handle bar that will do what I'm looking for?
Dan
British Columbia
2021 RE Meteor 350
Dan
What about 2" Rox risers? They can be adjusted to be closer to you as well.
paulcb
Celina, TX
'97/'01 ST1100 ABSII
8735
Any riser more than about an inch won't work with the ABSII ST1100... the brake line is not long enough.
I don't think different handlebars will work either because they too would move the brake master cylinder.
You're going to need a longer brake line.
Dan T
CT
2002 ST1100
On the ABS bikes, you can replace the brake line with one from a standard bike, it's long enough to use the 4" Major risers - it worked on my '97 ST1100A anyway...
I'll have to order a hose for the non-ABS model. You had the 4" Major risers on your '01? Did you have to change the throttle cables?
Dan T
CT
2002 ST1100
Any riser more than about an inch won’t work with the ABSII ST1100... the brake line is not long enough.
I don’t think different handlebars will work either because they too would move the brake master cylinder.
You’re going to need a longer brake line.
Thanks Paul. I know this is going to be some work but I think it will be worth it.
Dan T
CT
2002 ST1100
I may be entirely wrong, but I seem to remember investigating this once many years back when I got my first 1100 and decided that a part of the bars / brake lever / knuckles would connect with the fairing - which here in the UK would be an MOT failure.
Ya, that would be first thing I would look at when I change them out.
Versailles, KY
2018 GL1800 Airbag
8693
Helibars sells brake line extensions. I have 2nd generation Helibars on mine and love them. The first generation Helibars aren't as relaxed.
Dan T
CT
2002 ST1100
Did you have to replace the cables with the 4" risers?
I see ROX has a 3 1/2" that may work.
Versailles, KY
2018 GL1800 Airbag
8693
Another cheaper option I used for my Nighthawk were bars from a Goldwing gl1100. I wish I'd kept them when I dold my NH. You could order the hydraulic line extensions from Helibars so you wouldn't have to change the lines.
Dan T
CT
2002 ST1100
I'm actually looking for GL1100 handle bar now.
Looks like I have a couple of options for the hoses but I think the biggest challenge will be the cables.
Pennsylvania
1999 Honda ST1100
I know this is an old thread, but what did you end up doing on your handlebars?
