Been finishing off putting the bike back together today but have come up with a (minor) problem regarding the 6mm bolt collar sizes. I've reinstated both pannier rails with the necessary 8mm and 6mm bolts and collars using parts fiche to make sure I have the right lengths in the right place. This has now left me with 2x 6mm bolts and 23mm collars for the rear cowel (the front upper bolts above the side panel grommet). But when these are fitted the collars are too long and there is a gap of around 9-10mm between frame and rail. I've checked the parts fiche but they have the wrong part identified on the diagram so can't check the length. The only way to get near a solution without cutting down the collars is to swap the top rear (14.5mm) rail collar with the 23mm cowel collar. This leaves a bit of play in the rail at the 6mm mounting point (although the 8mm bolt above it secures it to the frame) but the tightens the cowel. I'm quite happy to cut the collars down but can't understand why there is a problem in the first place. Please does anyone have any ideas?
