Battery Terminal Bolt Specs?
SupraSabre
Cedar City, Utah
12/04 ST 1300s
000420
5901
Ok, so something like this fed by a 50A relay?
6 30A circuits / no negative buss / fed by 50A relay? With the possible exception of a GPS I wouldn't be using any of the labeled devices.
Huh. That pic turned out to be a little bigger than I expected.
When I hooked up my first Bluesea to my '05, I was using a 30Amp fuse and relay. I had the relays burn up twice, once while out on the road. I then moved to the 50amp and I have not had a problem since!
And one reason for the Bluesea, it can handle my 20amp horn without an issue!
SupraSabre
Cedar City, Utah
12/04 ST 1300s
000420
5901
+10 - I've run both Stebels and Fiamms through my Blueseas over the years with no issues either.
IIRC, I use a 50 amp relay and number 8 wire just to be 'safe'.
I run a 10ga wires to the fuse, relay and fuseblock. ;)
