Hello all. I'm having heaps of trouble diagnosing what is wrong with my ST. I had previously done a RWB on the main red wire, and found it was still melting fuses. Not blowing, but melting the plastic shell. So I swapped out the main starter relay and it stopped doing that. Then 4 months ago I went to ride home from work and my battery was dead, I quickly found out that it was not charging my battery. I have since swapped the old relay in and out to know avail.
First of all, the bike is putting out a charge, but it's not enough to charge the battery. Around 11.5 volts at 1000 RPM and up to 12.4 at 3000 rpm. I have since checked the alternator voltages (around 70ish volts on all 3 phases), resistance tests are with in spec. continuity on the wires seems fine.
I have tested and replaced the rectifier, thinking that was the problem, the first 2 cheap chinese rectifiers I have received have not worked for bad quality reasons, so while I wait on the 3rd from a different seller to arrive what else could it be? Ideally I don't want to dismantle the back 2/3s the bike to replace the 28A alternator if there is nothing wrong with it.
Any help would be appreciated. I am dying to get out and ride again while the weather here in Oz is good.
