Results 1 to 7 of 7
Thread: How to unstick a stuck carb float??
  1. #1
    been suggested by dealer mech to take screwdriver handle & tap on carbs to jar the float off the stuck position (stuck so that carbs 'bleed' gas out overflow)...ok, so this is a 91 vfr & after taking off the side panels i saw the back two carbs are the ones stuck & won't lift to shut off gas flow to bowls...bike ran perfect & sat for about a month)...too tight a fit in there to go knocking around on the carb bodies...someone suggested using hammer & tap lightly on carbs with handle of screwdriver on bodies...sounds risky!...anyway, over on vfr discussion group that i searched yesterday after registering found one response for someone there asking same question...the responder said to check to see which carbs are leaking by using a TORCH!!! so see into the dark areas...YEAH, RIGHT! SOOO...i want to ask my fellow st'ers for some reasonably plausible means to jar the floats from their stuck position without damaging carb bodies & without going into a "full carb overhaul(which was done about five years ago...) is there a "vibrator" for carbs?...no wise cracks, please...thanks in advance
  2. #2
    bcst1300's Avatar
    sold dec 31 14
    Join Date
    Dec 2004
    Victoria
    Posts
    265
    Tip Overs
    4
    My Gallery
    Re: how to unstick a stuck carb float??
    Hey Silver. The long screw driver and a light tap with a hammer is good. place the handle end against the float and tap the tip with a light plastic faced hammer. The "Tourch" is a flashlight in England. Sounds like the carbs need cleaning and a rebuild kit.
  3. #3
    bcst gave good advice there. I had lots of experience with a 1980 CB750K. I put over 150K ulitmately on that bike, had to deal with stuck floats on several occasions.
    Screwdriver on the carb, medium tap with a hammer gets the job done. However, its a sign that things are just going to get worse. You may as well learn how to rebuild the carbs now. Carb cleaner can get you by for a while, but if the bike sits long enough for the floats to stick other things are starting to setup.
    By the way... anyone want to help me get an '85 750 running that hasn't been started since 1993? It only has 7K miles on it and the owner just dumped it in my lap, saying "I'm tired of lugging it around everytime I move." Besides rebuilding the carbs (the hammer and screwdriver just ain't enough!) I'll be completely resealing (new gaskets and seals) the top end and probably the lower end.
    Motorcyclists understand why dogs stick their head out of car windows.
    http://www.touringmotorcyclists.com
  4. #4
    R.I.P - 3/20/2011 alan's Avatar
    Join Date
    Dec 2004
    Ottawa Lake, MI
    Posts
    683
    Tip Overs
    4
    My Gallery
    Quote Originally Posted by Dorian
    I still riding my 1969 CB750, had it out last week. I have had the sticking float many a times over the years. On mine, you can just pop off the spring clip that holds the float bowl and wiggle the float to free it up. I have 33,000 miles on this bike and bought it brand new. I have never had to rebuild the carbs.
  5. #5
    Andrew Seawell NCrider's Avatar
    '05 ST1300A
    Join Date
    Jan 2006
    Trinity, NC
    Posts
    617
    My Gallery
    After you break it loose, use Marvel Mystery Oil in the gas. This stuff WORKS!!!
    An old motorcycle mechanic turned me on to it. He said it cured 99% of the carb problems he had come through his shop and he was known as the best MC mechanic anywhere around.
    Andrew
    Live for today, yesterday is gone and tomorrow may never come.
    2005 ST1300A Previous Bikes: '74 Honda CT70: '74 Honda CB350F: '84 Honda 650 Night Hawk: '84 Honda V65 Sabre: '03 Honda VFR800A Interceptor.
  6. #6
    (Threadstarter)
    silverbub's Avatar
    Join Date
    Dec 2004
    illinois
    Posts
    333
    My Gallery
    thanks, fellas, for your helpful replies...i guess i will try the hammer(plastic)/screwdriver technique...i was worried about doing too strong of a "KNOCK" on the carb bodies castings...besides...it's hard to tell where the bowel part of carb bodie is on the little buggers...not as obvious to my eyes as it was for automobiles back when...and thanks, andrew, for tip/reminder about marvel mystery juice...i also am believer in it, but had not thought of it as being a good elexir after i get the two floats floating again...seems to me such a common problem would have ment that mechanics would have come up with some "slam-hammer" gadget or an "impact" imparting gadget that would be safer & better than hammer/screwdriver...think about having a spring loaded mechanism that would impart somewhat random shockwaves through carb body sufficient to shake up those floats off their stuck points...or an electrical device that would be shielded, of course, that would send random shock waves on the carb body/internals...
  7. #7
    (Threadstarter)
    silverbub's Avatar
    Join Date
    Dec 2004
    illinois
    Posts
    333
    My Gallery
    Re: How to unstick a stuck carb float??
    thanks to all of you fellas' advice & encouragement...i now have the floats on number 1&3 carbs on 91 vfr doing their intended work again...w/o having to "go-deep" & pulling carbs...i took a long oak dowel that will go into the stove come winter...and grabbed the 2 1/2 pound short handle sledge hammer & spent time tapping progressively harder on the carb bodies(after pulling side panes, of course)...number 1 carb float broke free of being stuck rather soon...heard it "ping" as it rose in the bowl...number 3 carb float took longer & was a multiple days affair...bang on carb body for awhile with & without engine running...(& having gas overflow from bowl)...until i got concerned about engine getting too hot & too much gas on engine...then i would get glum & quit for day...few days later, with renewed optimism...went back to banging on carb body again...even used a steel socket extension to mildly tap a different shock wave into carb body...made a few mild dents on carb, but not functionally a problem...low & behold...#1 float broke free last weekend & i immediately put a pint(16 oz) can of "sea foam" cleaner/conditioner into tank & ran bike for a thirty mile trip...checking frequently for any more overflow of gas...none!...so, again, thanks to all of you i hung in there & did not have to go to the $mech route...hope my description can help someone else with similar problem...give the hammer/dowel, etc a try for a few days before giving up!...
+ New Posts
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
