Best Headlight Replacement Bulbs??
Cindy at Evitek had the F2s in H5 but I didn't ask about the H7s. I have yet to order.
Ron
Orlando
ST1100s
2432
I had a dinger on my ST1100 head light lens. Since I was replacing it, I bought a European head light housing. Problem solved! H4 fit right in place, no shims no snipping tabs. Install the lamp of your choice, swing the wire bale over the lamp and secure it. You're done! Plus the light disbursement is much better. The 1100 ABS II "brain" is right behind the lamps and there isn't much room for you to move your hands around.
The US DOT regulations about the 90 watt restrictions are a bit grey. I think the 90 watt rule applies if the head lamp assembly is like the 1100's and not 2 distinctive separate lamp housings.
STraymond
Cincinnati Area
'01 ST1100
8700
Is there a difference between the UK headlight housings and those on the Pans sold in the European countries that drive on the right side of the road?
I haven't found the reg to read it but I think what you said is exactly the crux of the reg. The 1100 and 1300 have similar headlight assemblies in that there is no physical optical border between the two.
It seems most every other relatively moder bike with two completely separate headlights ships with H-4 style bulbs. I don't know if that holds for bikes with factory LEDs. I'd hope so.
Hinckley UK
ST1100AY/EZS sidecar
Yes it is a different headlight housing for the UK/Ireland who drive on the left side of the road.
Different Honda part numbers for UK/Ireland and mainland Europe.
Northumberland UK
VStrom 650
I'm pretty sure my UK bike has a flat dip so why would EU have a different unit. Mines marked Stanley 5266, it takes two H4.
Upt'North.
