Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
Thread: Any Good?: New $3 Walmart ST6607 and the ST7317 Oil Filters
  1. #1
    Dan Mulkiewicz dmulk's Avatar
    Join Date
    Apr 2006
    San Diego, Ca
    Posts
    2,502
    My Gallery
    Found this over on the KLR and GL1800 threads..... looks to be under $3 per filter @ local Walmarts. Figured I would pass it on.
    Same company that makes the Mobil 1 filters (champion) make this filter for Walmart.
    http://groups.msn.com/gl1800/general...66675666844976
    Will they work for the ST?
    Any good?
    Cheers!
    <D>
    STOC# 6451
    KLRST# 0002
    Dmulk's Blog
    "Balls sold separately" - MCL Website
  2. #2
    Jon Ransom illzoni's Avatar
    ST1100
    Join Date
    Jan 2005
    Tucson AZ
    Posts
    1,007
    My Gallery
    Re: Any Good?: New $3 Walmart ST6607 and the ST7317 Oil Filters
    Many have been using the ST7317 for years. I've been unable to find them at the local Walmart (since moving from Tucson to Ventura).
    I may try the ST6607 after reading that link.
  3. #3
    Ventura Highway wjbertrand's Avatar
    Join Date
    Feb 2005
    Ventura, CA
    Posts
    4,727
    My Gallery
    I was using the ST7317 as it had impressive first and multi-pass efficiencies claimed on the box label. Lately, when I can find them, I noticed that this information has been removed. The filters look as though maybe they are using a different supplier as well. I've quite using them since I noticed the change.
  4. #4
    Frank Wells Wheels of Fire's Avatar
    05 ST1300
    Join Date
    Feb 2007
    Hutsonville, IL 20 minutes from Moonshine (as the ST flies)
    Posts
    142
    My Gallery
    I've been using them with no problems, I usually buy 4 at a time so I have it handy for the next oil change.
  5. #5
    ST1100
    Join Date
    Jan 2005
    Tucson AZ
    Posts
    1,007
    My Gallery
    Oh, I'll be buying in quantity next time I find them!
    Last time I was in Walmart, I did my usual check for oil (Rotella) and filter. Surprise...they had two gallons of oil. Bought both. Now I need filters.
  6. #6
    Team Colorado ChucksKLRST's Avatar
    2014 FJR1300A,
    Join Date
    Dec 2004
    Aurora, Colorado
    Posts
    3,487
    My SPOT
    My Gallery
    I have used the ST6607 and have no problems to report. Presently I have a honda filter on the bike, but the next oil change I will use my remaining ST6607 that is sitting in the garage. The info on the other forum was intresting reading.
    Chuck Henderson (US Army RET 1968-1991) (Forever Home ? Colorado) STOC# 086,
    RIDE a little FASTER, RIDE a little FURTHER
    14 FJR1300A (Ruby FeeJeR) 14 DL650 ABS (Wee ll)
    17 VX300 (Little Gray Bike) The LiST
  7. #7
    Matt Kaminski UNTMatt's Avatar
    2006 ST1300 (Sold)
    Join Date
    Mar 2006
    Fort Worth, Tx
    Posts
    3,533
    My Gallery
    I just picked up a ST6607 from Wal-Mart just to check it out in comparison to a OEM Honda filter. Exactly the same size. However, in the link Dan provided, that thread is of 2004 vintage and it seems there are some discrepancy between the filter I have and the one he reveiwed in the link.
    The one I just picked up has a flat gasket unlike the semi-cicurlar o-ring type found on the OEM filter. There is no indication on the box that it is still made by Champion so I have sent an e-mail to Champion asking about the Super Tech filters. I'll post their response if/when I receive it. It seems that with the additional pleats in the ST6607 there isn't much filtering difference between the longer ST7317 and the ST6607 but I'm no expert in the matter...
    I took the cross reference from Wix site where the Wix 51365 fit other cars and took it to Wal-Mart and plugged it into the little computer thingy and it spit out the ST6607 for all the one's I checked. The only thing I scribbled on the print out before I left was the ST7317 from the Calsci website. I honestly had no idea about the ST6607 until I got to Wal-Mart. This is all out of a spark of curiosity.
    I did find these spec's posted on GWRRA Message Board from a response to a email sent to Champion:
    "Mr. Kutka -
    Please find attached engineering specifications for ST6607 (Champ equivalent part number PH2876).
    Thank you for your inquiry, let us know if we can be of further assistance.
    Mike Boyer
    Director Retail Sales & Marketing
    Champion Laboratories, Inc.
    PH: (618)445-5514 "
    PHYSICALS:
    Length (seam to dome) - 2.49 "
    Diameter - 2.70 "
    Anti-drainback Valve - Yes
    Thread Size - M20 x 1.5
    Relief Valve - 11 - 17 psi
    Gasket O.D. - 2.47 "
    Gasket I.D. - 2.20 "
    MEDIA:
    Area - 59 Sq. In.
    PERFORMANCE:
    Based on SAE HS806
    (RFO-3 180?F, Flow Rate 3 GPM , Add rate 1.5 grams/hr., FTD, Terminate @ 8 psid)
    Hydrostatic Burst Strength, min. - 350 psi
    Element Collapse Strength, min. - 75 psi
    Capacity - 2.0 Grams
    Weighted Average Efficiency - 83 %
    Impulse Fatigue Strength - 0 - 100 psi, 25,000 cycles
    Anti-Drainback Leakage - 12 ml/hr. max.
    This is the spec's of the Wix 51365 m/c filter that is a direct replacement for the ST1300:
    Part Number: 51365
    UPC Number: 765809513655
    Principal Application: Ford (92-97), Honda (00-07), Infiniti/Nissan (95-08), Mazda (97-07), Mercury (91-96), Saab (05-06), Subaru (88-08), Cub Cadet, Yanmar, John Deere, Kawasaki, Kobelco, Outboard Marine Engines
    All Applications
    Style: Spin-On Lube Filter
    Service: Lube
    Type: Full Flow
    Media: Paper
    Height: 2.577
    Outer Diameter Top: 2.685
    Outer Diameter Bottom: Closed
    Thread Size: 20X1.5 MM
    By-Pass Valve Setting-PSI: 8-11
    Anti-Drain Back Valve: Yes
    Beta Ratio: 2/20=15/22
    Burst Pressure-PSI: 300
    Max Flow Rate: 9-11 GPM
    Nominal Micron Rating: 19
    Gasket Diameters
    Number O.D. I.D. Thk.
    Attached 2.475 2.173 0.233
    "Life is always a choice between greater and lesser risks -- zero risk is not an option." John Stossel
    "Complaining about the heat in Texas is like complaining about water for being wet." Reliant Energy
  8. #8
    2006 ST1300 (Sold)
    Join Date
    Mar 2006
    Fort Worth, Tx
    Posts
    3,533
    My Gallery
    Just got this response back from Champion:
    Matt,
    Yes we are still manufacturing the Super-Tech oil filters for Wal-mart. Although I am limited to what info I can give out being it is proprietary info if you let me know specifically what specs you are needing, I will see what I can do to help you out.
    Bob Buckman
    Tech Rep
    Champion Labs.
    I sent a list of spec's I'd like to see and I'll post his reply. I somehow doubt I'm going to get much, though.
  9. #9
    Rob__'s Avatar
    2006 St1300
    Join Date
    Sep 2007
    SC
    Posts
    628
    Tip Overs
    1
    My Gallery
    Quote Originally Posted by NightRDR View Post
    Oil filter.... Do they make an air filter for $3?!!!
    Rob
    '06 ST1300
    '06 Triumph Speedmaster (SOLD)
  10. #10
    2006 ST1300 (Sold)
    Join Date
    Mar 2006
    Fort Worth, Tx
    Posts
    3,533
    My Gallery
    Here is his final response:
    Matt,
    The ST6607 is 2 1/2" in height , 2.65 in OD, and has a M20 x 1.5 thread. This filter has been design ed to meet all of the OE requirements for fit and function. It has a Pressure relief valve and a anti drain back valve as well. They were designed to be comprobable to a Fram filter. The rest of the info is propritary to Super-Tech and I don't even have a way of looking that up. Sorry for the inconvenience.
    Bob Buckman
    Tech Rep
    Champion Labs.
    Since they are still manufacturing the filters, I'd think that the spec's are probably the same as the response someone else had better luck with that I posted above.
+ New Posts
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
