Results 1 to 9 of 9
  1. #1
    kanem's Avatar
    98 ST1100
    Join Date
    Mar 2007
    Valparaiso, FL
    Posts
    361
    My Gallery
    Fail Open Thermostat?
    Does anyone make a fail open thermostat for the ST1100?
    Mike Kane
    STOC# 6215
    1998 ST1100
  2. #2
    STArnie13
    Join Date
    Dec 2004
    Wichita, Ks
    Posts
    597
    2013 Miles:
    004967
    My Gallery
    Re: Fail Open Thermostat?
    I'm not sure what you are looking for. What is it you are trying to accomplish?
  3. #3
    Ventura Highway
    Join Date
    Feb 2005
    timbucktu
    Posts
    5,335
    My Gallery
    There is a cross-reference to a Honda car (late 90s Civic I think) t-stat that will fit the ST1100. Since there are a lot more Civics than STs around Stant and several other aftermarket companies make t-stats to fit. Someone here can probably produce the Stant part number.
    One can buy "fail-safe" type t-stats for many cars, maybe they are available for the late 90s Civic too. MotoRad (http://www.motoradusa.com/index.html) makes these fail safe ones. I looked up the number for a '98-'99 Civic Ex and got this:
    Fail Safe Thermostat 7328-170 170 degree. O.E. Recommended Temperature
    You'll want to confirm whether this is the car and engine the ST1100 shares a t-stat with to be sure first.
  4. #4
    (Threadstarter)
    kanem's Avatar
    98 ST1100
    Join Date
    Mar 2007
    Valparaiso, FL
    Posts
    361
    My Gallery
    STArnie,
    A fail open thermostat does exzctly what is says. When it fails it stays open to continue to allow coolant to circulate and cool your engine. A normal thermostat failes closed and stops the coolant from circulationg to the radiator then your enginge overheats. Aluminum engine overheats you get warped heads and all sorts of other nasty stuff. I've been fortunate to experience the overheating one time and got rid of the vehicle before it was too late. The overheating was from a different problem in that case though.
    Mike Kane
    STOC# 6215
    1998 ST1100
  5. #5
    Site Supporter EdsST's Avatar
    ST1300A
    Join Date
    Dec 2004
    Panama City, FL
    Posts
    398
    Tip Overs:
    1
    My SPOT
    My Gallery
    All of the Thermostat failures on the 1300's have the thermostat failing by being stuck open. I was under the impression that was the standard.
    Ed Williams
    Panama City, FL
    STOC #1307
    STX #621
    Iron Butt #7060
    05 ST1300A
  6. #6
    I Hate Snow Hashimoto's Avatar
    2006 ST-1300
    Join Date
    Jul 2006
    Maine
    Posts
    223
    Tip Overs:
    2
    My Gallery
    Sticking open seems to be what the Honda thermostat does anyway. I've not seen a mention of one sticking closed.
    I'm in the process of installing a st thermostat that I bought from Turbo City. It's made by MotoRad, an outfit that makes parts for BMW.
    2006 ST-1300
    STOC 6569
    I'll keep my Freedom, Guns and Money, you can keep the "CHANGE"
  7. #7
    Ventura Highway
    Join Date
    Feb 2005
    timbucktu
    Posts
    5,335
    My Gallery
    I know of one case (Jon Ransom's '91 ST11) where the t-stat failed at least mostly closed. According to Jon's photos it appears to be because the strut that the wax motor pushes against to open the valve corroded through and broke.
  8. #8
    Join Date
    Dec 2004
    San Jose, Ca
    Posts
    152
    My Gallery
    On the 1100, at least, they can definately fail closed. It happened to me out in the middle of Oregon returning from WeSToc up in Idaho and I blew one of the coolant hoses that goes to the heads. What a hassle. The part of the thermostat actually fractured off and the thingy that pulls the valve open against the spring then no longer had a grip on it. Coolant flow kept it in place, though, plugging the only hole (besides the bypass hole) that coolant could flow through. After the hose blew and I shut the motor down, the "thingy" dropped away and down, exposing a hole in the middle of the valve and though I didn't discover this problem until after I got home, it did allow enough coolant flow to get me home.
    Go here for some pix: http://www.my-mc.com/messages/1/25613.html
    A fail open thermostat would be a nice idea, methinks.
  9. #9
    STArnie13
    Join Date
    Dec 2004
    Wichita, Ks
    Posts
    597
    2013 Miles:
    004967
    My Gallery
    Mike, thanks for the info. I had never heard of a fail safe thermostat. It sounds like it might help others as well.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
