I am out of stock on these screws and am having a difficult time getting to use the machine at work to make new ones. I will keep trying, and maybe later this month I will run another 100 or so. I will keep you posted.
I am going to be out of town from 5-16 to 5-29. I will ship any screws ordered during this time before 5-31.
4-21-2011 Due to the latest postal increase I am have to increase the shipping $.50. The previous 2 increases I absorbed, but this last one was quite a jump.
As of 5 - 23 - 2012 I still am making these screws and will continue to.
Replacement Security Screw for the Zumo 450 / 550 motorcycle cradle. It is made of 303 stainless steel. Just remove your old screw and replace with this one. You no longer have to carry the special screw driver or need 20/20 vision to see where those slots are that it fits. This screw will not prevent your Zumo from being removed from the cradle by some unauthorized person.
I am including a small o-ring (size 003) with each screw. Sorry for the early shipments, for they do not have one. I found that when I removed the factory screw and replaced with mine the very small o-ring got cut in half. I ordered a larger walled one and am including one with each screw. I was able to place it in between the clamping arm and base. Close the clamp and screw the new screw in. You may need to use a small pick / tooth pick to help get the o-ring lined up before the screw is put in. This should keep from losing the new one. Another method would be to tighten the screw after removing your Zumo. That would be the best way.
Pricing is $5.00 each and $3.00 for shipping charges per package delivered to US addresses. Shipping will be $3.50 to non US Addresses.
