Article [13] ST1300 - Rear Flange Bearing Replacement
000540
Sorry, late to the conversation but looks like Dave got you covered!
As usual thank you dduelin :)
Curious, if there's any other check/way I can test sistered bearings inside the flange before I pull them out? Also, should I clean and repack them with fresh grease too?
Well, note the collar is a press fit inside the two bearings.
You should be able to easily press or tap the collar out from the outboard side and the bearings will remain pressed into the splines hub. You can check both bearings together with the collar in place or separately with the collar out. With a finger inside the collar lightly rotate the collar/bearing assembly. You will feel any roughness attributed to one of those bearings. If all is smooth then put it all back together and call it good.
No VA, DC
Well, note the collar is a press fit inside the two bearings. With a finger inside the collar lightly rotate the collar/bearing assembly. You will feel any roughness attributed to one of those bearings. If all is smooth then put it all back together and call it good.
Yes, it spins very smoothly in both directions and don't feel any obstruction or roughness. Thanks again Dave...
T_C
St. Louis, MO
2005 St1300
8568
So I have removed it and grease seems to be dry on the bearing,
If I'm reading this correctly.. some clarification is needed.
Grease on the outside of the bearing does nothing, what you are probably seeing is dried moly grease from the spline lubes. Those are sealed ball bearings suporting your tail wheel, you can't pull and pack them like tapered wheel bearings. Yes, technically you could pry up the seal, inject some fresh grease underneath. It's debatable if doing this really helps as you are leaving the worn out base grease behind.
You can put some grease on the inside of the bearing, but this just helps the axle slide through and prevent corrosion. Do not use moly grease here, not enough movement.
No VA, DC
Sorry for the confusion, yes I have put everything back together and left those bearings alone since they were smooth and doing fine.
MerlF
Chuck Welsh
BC
ST1300AD 2013
Anyone know the torque value for the four large nuts on the flange drive. They were really tough to get off.Driven Flange.jpg
BakerBoy
It's all small stuff.
Golden, Colorado
1408
@MerlF
Service Manual, p.1-17, shows "Final Driven Flange Nut", Qty 4, 14mm thread diameter, 150 N-m (111 lbf-ft), with a note that his is a "U-nut".
The Rear wheel removal, disassembly, and reassembly procedure, p. 16-5 to 16-10 just says "install the driven flange assembly to the right wheel hub", no torque for that fastener is listed in that section.
The U-nut appears to be part 90305-GE8-003, but I don't find another source of acceptable torque for it.
Please verify it is 14mm before using the torque I mention here. Or someone else can corroborate that is the correct torque.
MerlF
Chuck Welsh
BC
ST1300AD 2013
Thanks BakerBoy, these are the toughest nuts to take off I've encountered on the bike. I should have read this series of posts first. Just checked the manul and it is as you say. 111lb/ft, no wonder they were so tough to get off.
nt650hawk
Gino
MA
victim here to the bearings going . 04 ST with 30K miles. Maybe 130mph at a recent track day had something to do with it. :think1: 1 month ago it was fine. Putting on new rubber I got the marble feeling as i was inserting the axle. I extracted the bearings and they had that crunchy feeling after a mineral spirit cleaning.
my previous 06 with 60K had no such issues.
Sadlsor
Birmingham, Alabama
2008 ST1300A
9065
Glad to note that while mounting my new CT to the ST this past week, I cleaned the old moly and re-lubed it, and checked these flange bearings (30k miles) and noticed no notchiness or sloppiness back there.
I hadn't seen this article, having no need through the years, but while I've changed wheel bearings before (only on my inline skates[!]), for some irrational reason I've always slightly feared replacing wheel bearings, maybe because of their critical nature. I dunno.
Having read this now, it's not nearly as intimidating as I'd feared.
I've also learned that much of the "fear" of tackling ST maintenance chores is really more tedious or time-consuming, than actually difficult to perform.
Have I told y'all lately how much I love st-owners.com?
New Bern, NC
Thanks Mellow for this great instructional article and all the comments from forum members as we'll. It gave me the knowledge and confidence to tackle the job. Just a note to help others who may use this thread, I removed the distance collar with bearings from the flange in Step 3 with a 21 mm socket and extension. I then removed the bearings from the distance collar using a 11/16 socket and extension. Light taps with a two-pound hand held sledge seemed to work well in removing the parts.
