Mike Martin ST1100 Maint. Pages
000540
Lots of great info from Mike's site:
Engine & Drive Train
1. Carburetor Draining (Part of prepping your bike for storage.) [Nov. 24, 2004]
2. Carb Sync with an STE Synchrometer (You're gonna' have to know right from left.) [Apr. 30, 2006]
3. Coolant Leak Under the Carbs (Essence d'antifreeze, or a tiny puddle under your ST) [Apr. 30, 2006]
4. Cooling Fan Noise (What the heck is making that racket?) [Jul. 9, 2001]
5. Cooling System Pressure Test (You can do this without a lot of tools.) [Feb. 24, 2009]
6. Changing Cooling System Hoses and the Timing Belt (This is often done together.) [Jul. 3, 2006]
7. Fuel valve repair (How to install the K & L kit.) [Feb. 20, 2004]
8. Help - my bike's a slug! (Carb diaphragm failure.) [Dec. 27, 2007]
9. High Coolant Temperature (But there's plenty of coolant in the overflow bottle.) [Aug. 13, 2006]
10. Intermittent Misfire One of the toughest problems to diagnose. [Aug. 2, 2005]
11. Oil Change Tips (Makes the job a little easier.) [Dec. 12, 2008]
12. Oil Filters (What can I use?) [Jul. 22, 2004]
13. Radiator Drain Job (Don't worry about those block drain plugs.) [Oct. 30, 2006]
14. Rear wheel O-rings (Where is that 3rd one? And what kind of lube & where?) [May 29, 2005]
15. Rear wheel won't fit? (Probably that pesky distance collar.) [June 26, 2005]
16. Shifter Tune-Up (Missing shifts? Maybe this'll help.) [Mar. 28, 2004]
17. Sub Air Filter (What is it and should I care?) [Dec. 20, 2007]
18. Swingarm R&R (It's not that big a job.) [Dec. 5, 2002]
19. Valve Adjustment (Tips to facilitate the service manual procedure.) [Jul. 19, 2004]
Chassis
1. Brake Relining Tips (Improve the caliper operation.) [Feb. 9, 2004]
2. Bleeding and Flushing Brakes and Clutch (You need to do this every year or two.) [Mar. 9, 2001]
3. Dings in your Forks? (Maybe you can salvage them.) [Jun. 4, 2002]
4. Making a mess changing fork oil? (This part might help.) [Sep. 8, 2004]
5. Suspect a problem with the fuel pump? (Try these suggestions.) [Jul. 17, 2004]
6. Steering Head Bearing Replacement (Get rid of those old clunkers.) [Jul. 9, 2006]
7. Tapered Steering Head Bearing Adjustment (This is a bit of a mystery to many.) [Jul. 9, 2004]
8. Wheel Balancing (Easy when you know how.) [Feb. 2, 2004]
Electrical
1. 28 Amp. Alternator Checkup (I'm getting 12 volts, is that OK?) [Jan. 23, 2004]
2. 40 Amp. Alternator Installation (Cheaper and better than the 28-amp. model on your pre-1996 ST.) [Aug. 2, 2006]
3. Bank Angle Sensor (Why'd my bike quit?) [Jul. 9, 2001]
4. Electrical Loads for a '91 ST (Can I add those driving lights?) [Jul. 9, 2001]
5. Fuel Light Malfunction (Is your fuel light ON when it's supposed to be OFF, or vice versa?) [Apr. 14, 2003]
6. Headlights Inoperative (Yikes, it suddenly got dark!) [Dec. 26, 2002]
7. Ignition Switch Tune-Up (You don't want road-side down-time!) [Jul. 13, 2006]
Body
1. (Gas cap hard to open? This will cure the problem!) [Jul. 2, 2002]
2. (Grab Bar Bracket) (Is your trunk starting to sag?) [Dec. 12, 2001]
3. (Fix your broken mirror!) (Save a few $$.) [Jul. 9, 2001]
4. (Fix your broken plastic!) (Save a lot of $$$.) [Mar. 26, 2005]
5. Touch-up Paint (Keep that ST lookin' good.) [Feb. 21, 2005]
6. Windshield Restoration (Make that stock windshield look new again.) [Dec. 12, 2008]
000540
Wow! Anybody done this for the 1300 (all in one place)?
We do have the articles section, but if you want a one-page reference, I can work on that easy enough. Also, the STWiki has a ton of info, I'll see if Mark has an easy way to reference stuff in one page.
000540
Don't thank me.. go to Mikes site and let him know you like it. Or PM him here.
STurgisSTeele
When did I become the "Old Man"!?
STurgis, MI
01 ST1100A (RIP)
2667
FYI, the website moved. But the above link to Mike's site will land you on a page that redirects you in 10 seconds.
Peace and All Good
Mark
Gotta make tracks
Moderator
Apache Junction AZ
KTM 525exc
3768
Peace and All Good
Fixed the link in the 1st post.
Thanks for point out that it needed to be changed.
Williamsport, PA
4138
What we really need is a USB port on the bikes that you plug your laptop into and if there is a fault somewhere, the correct page of instructions to deal with it automatically pops up.
Hey, I can dream can't I?
