ST1100 Sub air filter replacement!!!
0204bit
Earlygo
MN
'93 ST1100A
Somewhere I read a tip that the sub air filter should be checked every now and then. I checked my 1993 St1100A with 104,000 miles and the filter had a hole in one end and it fell apart in my hand as I took it out. The filter box is just in front of the carburetor air filter in a little black box with a hose attached to either end. This an easy thing to check when you have the fuel tank/air box plastic off (2 bolts and 2 allen head screws).
I took a new foam filter for my mower air cleaner and cut out a replacement filter with a band saw. That way I wouldn't have to wait for a factory replacement part to arrive and it may have saved me some money.
Coventry, UK
White ST1100AV
7881
I've heard reports that the airflow through a foam style filter is more restricted than with the paper OEM ones, which would cause rich running. It might be worth getting a pattern part of the same construction type...
Cheers & God bless
Sam "SammyTheSnake" Penny
Kingman, Arizona
2000 ST1100 ABS TCS
004
The main air filter is pleated paper but the aux filter (filters the air coming back from the crankcase) is foam. Adam C. made some from some grey packing foam one time. Looked OEM.
New Port Richey, Fl.
'93 ST1100
That photo is the primary air filter.
Original poster is refering to the sub-airfilter located just forward of the main air filter, roughly 2"x1"x0.25" in size
Mark
Gotta make tracks
Moderator
Apache Junction AZ
KTM 525exc
3768
Sammy,
The next time you pull the shelter and air filter cover on an ST1100 take a look at where the 2 tubes connect in the front of the air filter cover.
You'll find a small rectangular box with the filter being discussed here.
Mark
Benton, AR
1991 ST1100
7908
I made mine from a generic green foam outer lawn mower filter. No problem. I also use this for my air compressor filter.
Ralph Sims
Coventry, UK
White ST1100AV
7881
Well well well, I knew the ST was a bit greedy, having two exhausts and three brakes systems and such, but I didn't realise it had two air filters :p
Cheers & God bless
Raymond, WA.
7432
Made one out of a foam paint brush until the OEM replacement got in.....The OEM replacement looked a lot like it was made out of a foam paint brush.... :)
'91 ST1100
'05 Road Star
tmills
Nova Scotia, Canada
2000 ST1100
8745
Just checked mine, it fell apart, thanks to you guys for the idea I made one out of a lawnmower filter, a bread knife cuts it just right.
Sent from my iPad using Tapatalk
Fort Worth, Texas
91 ST1100/06 ST1300
If you roll your own...please use foam suited to petroleum atmosphere....such as from an automotive/motor vehicle air filter or lawnmower. Many foams will decay quickly when exposed to gasoline fumes.
Lexington, KY
1998 ST1100
8643
What I pulled out of mine last winter looked like it came from the kitchen sink rather than the parts department! I replaced it with an OEM one.
Joseph/TX
R.I.P. - 2016/11/13
Magnolia, TX
1994 ST-1100A
Okay, somebody enlighten me. I've seen that sub air filter on the parts blowup in my service manual and been wondering ever since. Getting ready to replace the big one anyhow, so I suppose I'll do this one too. Still trying to figure out why it's there....
Slydynbye
Will ride for Pie
Fremont, California
2000 ABSII
7331
Interesting question, I thought it had to do with the airflow to the vacuum actuated slide without introducing dust or other particles. I would guess that if it was plugged the carb would stop operating properly. Also if it disintegrates the little bits would play games with the slide operation.
Joseph/TX
R.I.P. - 2016/11/13
Magnolia, TX
1994 ST-1100A
An excellent point. I'm tempted to think I'm better off without it. My 1980 XS 11 has run up 150K without any such filter, so why does my ST need one?
