Redback
The Reverend Padre
ST '05 model with 20,000 klm - I have a problem with cold starts which is most strange. If I park the bike overnight or for say 8hrs during the day on the centre stand, the auto choke (fast idle on cold) 3 in every 5 times it wont cut in causing the engine revs to drop rapidly and it stalls. It will restart but I have to hold the revs up manually or it stalls until the engine reaches full operating temperature. The engine doesn't run rough or cough and spluttter -- BUT, if I park the bike on the side stand I don't experience the problem. I use good quality HO fuel and about every third fill of fuel I add Motul fuel injector cleaner. Once hot, the bike runs even and steady and ticks over at 1,000 revs idle.
I get no 'fail' warnings (blinking) on the EFM F1 dashboard light so my first thoughts are contaminated fuel. I figure maybe that on the upright centre stand the fuel pickup sucks in some rubbish (water or ?) causing the auto choke not to work but on the side stand, the contamination falls to the side of the tank and doesn't get sucked up on starting. Otherwise it may be something buried deep in the electronics or wiring ?? Before I start draining fuel tanks and spending $150 to change fuel filters (what twit put it inside the tank?) has anyone else had this problem or know a likely cause ?
PS: I see an older post that related to loose throttle body clips allowing air in through that seal - could this be it ? but why does have the bike on the side stand have any affect ??
