I look for some information about spring Hyperpro
France
Hi
I am a new member of your forum and I would like to know you feeling about the spring Hyper pro mounting on the ST1300 fork.
I am french and sorry about some mistake language :bow1:
I am owner of ST1300 since 09 May and I have a critical position about the fork of this motor cycle.
In fact, I think my fork have a short clearance and this point is bad for me. (not confortable) Unfortunatly the quality of the way and motorway is more bad that is your country USA)
The rear shock absorber is very confortable and I would like improve the quality of my fork.
I hope your advice and experience with this accessory.
Thank a lot :biker:
How much do you weigh? If you are 75 kilograms or less you may just require longer spacers in the forks. This adds "clearance" to the Honda fork by increasing the preload on the springs.
France
My weigh is between 85 and 90 kg and I believed that the spring Hyperpro was more progressive that the standard spring !
My feeling is the clearance of the orginal system is too hard :biker:
If I understand the spring Hyperpro isn't a good solution to improve the comfort :confused:
Mark
Gotta make tracks
Moderator
Apache Junction AZ
KTM 525exc
3768
There is nothing *wrong* with the HyperPro front springs. They improve the handling of the front end.
When you change the fork springs you set the sag by installing a spacer.
Then you measure (with you on the bike) the sag and take the spacer out again and cut it (or cut a new one longer) to the correct length so it is correct for your weight.
I'm am sorry that I can explain this in French for you...
Regards,
Mark
SteveST1300
Vendor
Ledgewood, NJ 07852
03&04 ST1300
5079
I have the Hyperpro springs and they are speced out to my weights 2 up with luggage etc. They figured out the correct specs and they were spot on. I did not have to adjust anything just install the springs and oil.
France
And what is your feeling about the comfort ? improve or not
Thank a lot Mark, Steve and dduelin for your help beacause in my country we haven't experience with this accessories.
Regards ;)
Mark
Gotta make tracks
Moderator
Apache Junction AZ
KTM 525exc
3768
First: I weigh 83kg without my riding gear.
With the Honda stock front fork springs I would bottom out the front end.
With the HyperPro front fork springs I have not bottomed out the front end.
A caveat: I use 15wt oil with these springs because I like a stiff suspension. I tried 20wt oil but didn't like the feel.
Mark
France
I am not sure to understand because when you explain :
I understand that with the standard springs the clearance was max !
And with the HyperPro front fork springs your clearance decrease !
Personnaly with the standard springs the clearance is too short and I feel the shocks in my arm.
In addition my oil is SAE10 standard.
With the Hyperpro I hope a fork supple over the small shock and hardiest of the big shocks.
I hope you understand me :confused:
Mark
Gotta make tracks
Moderator
Apache Junction AZ
KTM 525exc
3768
Sorry for my poor wording.
Yes: the clearance was too short with Honda stock front springs (bottomed out) with the standard Honda oil.
SAE10 == 10wt, I use SAE15.
Supple is a good word, I have used 'smooth'; but, I think we mean the same thing.
Hope this has helped; sorry for the confusion,
Mark
SteveST1300
Vendor
Ledgewood, NJ 07852
03&04 ST1300
5079
The hyperpro springs and the shock made the ride of my ST1300 much better than it was. I was bottoming out on the stock springs and shock, mind I had well over 60k miles on the stock springs and shock. The improvement was both in the ride and handling.
