Results 1 to 8 of 8
Thread: Size of front brake caliper Allen bolts
  1. #1
    While I live most of the year in MA, my '06 ST stays in NM. I'm gearing up for a tire change next NM visit and need to know what size allen socket is needed to remove/replace front brake calipers. I gathered from extensive review of site archives that 17 mm allen and 22 mm socket are needed to remove front axle but can't find info on caliper allen size.
    Also, what tools are needed for rear wheel removal, i.e., socket size for axle (if ST has a rear axle or like my R11RT bimmer uses lug bolts) and for muffler clamps and mounts (as I understand moving muffler out of way is helpful when removing rear wheel).
    Thanks in advance for the info.
    Wondering Wooster
  2. #2
    thunderfootblue's Avatar
    Join Date
    Mar 2007
    Omak, Wash.
    Posts
    417
    Tip Overs
    2
    My Gallery
    Re: Size of front brake caliper Allen bolts
    Front:
    12mm socket with extension (2 right caliper bolts)
    6mm allen/hex bit socket (two left side caliper bolts, 4 front axle pinch bolts)
    17mm allen/hex bit socket & 22mm wrench/socket (front axle)
    Rear:
    5mm allen/hex bit socket (to remove rear fender)
    10mm and 12mm sockets (to loosen right & left side muffler (swing mufflers down, 4 bolts each) Note: loosening the left makes for easier access to caliper stopper bolt
    14mm wrench/socket (to remove caliper stopper bolt)
    8mm allen/hex bit socket (to hold rear axle)
    27mm wrench/socket (to remove axle nut)
    Medium anti-seize on caliper bolts & caliper stopper bolt
    I think that's it.
    Last edited by thunderfootblue; 08-20-2009 at 09:37 PM. Reason: Correct size of allen/hex bit socket from 6mm to 8mm (to hold rear axle)
    Jeff
  3. #3
    (Threadstarter)
    wooster's Avatar
    Join Date
    Oct 2007
    Danvers, MA
    Posts
    15
    My Gallery
    Great info.
    Thanks a Bunch !
    Wooster
  4. #4
    Vendor SteveST1300's Avatar
    Join Date
    Dec 2004
    Ledgewood, NJ 07852
    Posts
    5,337
    Tip Overs
    4
    My Gallery
    I thought the right side allen key was an 8MM on the rear end.
    2003 & 2004 ST1300 IBA# 32834
    USAF Retired STOC# 5079
  5. #5
    Join Date
    Mar 2007
    Omak, Wash.
    Posts
    417
    Tip Overs
    2
    My Gallery
    Quote Originally Posted by SteveST1300 View Post
    You're absolutely correct, Steve-O! Good catch. I've corrected my post & reference material.
  6. #6
    dond's Avatar
    Aprilia Atlantic 200
    Join Date
    Dec 2004
    Spring Valley AZ
    Posts
    1,314
    My Gallery
    "Medium anti-seize on caliper bolts & caliper stopper bolt"
    I would use blue loctite.
    Don
    '04 Aprilia Atlantic
  7. #7
    Gotta make tracks Mark's Avatar
    '04 ST1300, BLUE
    Join Date
    Jan 2005
    Tempe AZ
    Posts
    14,202
    My Gallery
    I would add a torque wrench to the tool list.
    If you love your bike, let it go.
    If it comes back, you high sided.....
  8. #8
    st1300r's Avatar
    st1300 '04
    Join Date
    Apr 2007
    New Jersey
    Posts
    8,053
    Tip Overs
    2
    My Gallery
    medium thread locker. careful on the color honda and loctite are different.
    Carl, SToc#7163, ST1300 '04
+ New Posts
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
