ST1300 part numbers
ST Dan
2 summers 50k+ miles 48 states
Canton, MI
14 NC700X
6693
I haven't purchased new brakes pads in a while, so I was getting around to looking up the part numbers to get them ordered...took me a while to find them. So I thought I'd start a thread of part numbers...feel free to add part numbers for whatever you feel would be useful to everyone. My thought is that if it gets enough parts list, Joe could make it a sticky, which would save everyone a lot of time when it comes time to order new parts...i got the numbers from ronayers.com
NO DISCUSSION.....JUST PART NUMBERS
front brake pads 06455-MCS-G01 (need 2)
rear brake pads 06435-MCS-G02
thermostat O ring 91631-MCS-A10
head cover gaskets 12391-MCS-000 (need 2, right and left are the same)
rear wheel damper set 06410-MCS-G00
oil filter Purolater pure one PL14610
autolite spark plugs 4303 copper core, .035 gap
hondaline top box plastic caps
08L42MCS80002 Cap A, there are four of these.
08L42MCS80005 Cap B, right, one of these (this has a small depression moulded in to match the carrier profile and is handed)
08L42MCS80006 Cap B, left, one of these (this has a small depression moulded in to match the carrier profile and is handed)
front turn signal/marker light (in the mirror housing) 34906-MBB-611
Frisco, Texas
2015 BMW K1600GT
Plastic rivet pins
91549-MWO-790ZA
(2)-Top of front lower cowl
(6)-Front edge of inner cowl
90116-MCS-G00
(4)-Windscreen cowl
(2)-Lid fairing. Spark plug/oil fill cover.
(2)-Top rear edge of the lower
90657-SBO-003
(4)-Windscreen cowl
(4)-Bottom front of fairing & lower cowl
(2)-Top rear edge of inner cowl
(2)-Rear fender Most people have not even seen these.
Frisco, Texas
2015 BMW K1600GT
Rubber mounts on the top of the plate between the GIVI top box and the mount plate:
Z126 rubber bumpers $4.00(set of 4).
These can be ordered through your local dealer or by contacting us (GIVI) at 1-877-679-4484
Arvada, Colorado
03 ST1300 ABS
Don't click on that link from JackieO because you get a "security alert" popup which is an annoyance.
