Results 1 to 9 of 9
Thread: How to clean air Compressor tank
  1. #1
    stoc445's Avatar
    2014 Kawasaki C14
    Join Date
    Jan 2005
    Owasso, Ok.
    Posts
    284
    My Gallery
    I've been bad. I haven't drained my compressor tank in a , long, long while. Started out with the drain valve getting stuck and went down hill from there. Anyway. I've been using it more and more, I feel the need to get it working properly.
    I got the drain valve off, but was surprised to just have a little dribble. The drain valve screws into a bushing, which will not budge. Hit it with an impact wrench today and still didn't budge. Need to figure a way to get this off then clean the tank out.
    Any idea on getting this bushing off and cleaning the sludge out of the tank?
    Denny
  2. #2
    ------------Jeff------------ Dinkie Diesel's Avatar
    2013 GL1800
    Join Date
    Jul 2007
    Defiance, Missouri
    Posts
    3,991
    My Gallery
    Re: How to clean air Compressor tank
    Is the bushing brass? Sometimes you can chisel away the soft brass and not ruin the threads of the steel tank. If/after you get it out you can rinse it with water. I'm not usre there's anything that can be done to resolve the rust issue. There are some products used to seal gas tanks that might work.
    Jeff
    The missing link
    Did you ever get the feeling the world is a tuxedo and you were a pair of brown shoes?
    I know I'm getting old, I was in Las Vegas last week playing the slot machines and 3 prunes popped up!
  3. #3
    sennister's Avatar
    '93 ST1100
    Join Date
    Aug 2007
    Grant, MN (aka Stillwater)
    Posts
    5,897
    Tip Overs
    1
    My Gallery
    I would try the option listed above to try and chisel it out. You might have to drill it out for the most part and then work at chiseling it out. As for dealing with the rust. You could try a rust converter. I have never tried it in a compressor application but I have used the stuff before. It is a liquid that is normally painted on but you could probably swish it around in the tank. It is pretty thin. I used it last when touching up the hitch on my truck. It was getting pretty rusted. I pulled it off and cleaned off what I could with a wire wheel on my grinder but there were lots of areas that I couldn't get into. I picked up some of this rust converter and hit the areas that I couldn't treat. Once it dried I primed and painted the hitch and it looks better than new.
    Here is an example of what I am talking about.
    Rust Killer
    I picked it up at a local store called Fleet Farm. I don't know if there are any in your area but check around any kind of farm supply stores. They may have something like this. The store that I bought it from had it in the same area as the implement (tractor) paint. It came in a plastic bottle kind of like Zippo fluid. It would be really easy to squirt it into a compressor tank. It has the consistency and looks like milk.
    Good luck
    STOC# 6145
    IBA# 53268
    1993 ST1100 non-ABS
    2003 ST1300 ABS (RIP)
    Too many Farkles to list. Take a look at bike mods in my profile.
  4. #4
    Team Aloha Paul's Avatar
    2008 ST13
    Join Date
    Jun 2008
    Hilo Hawaii
    Posts
    780
    Tip Overs
    1
    My Gallery
    I recently tore my compressor down to clean it up, change the belt, new oil, and re tape all the threaded joints. After it stopped filling for the first time, I heard a small leak and thought it was the ball valve on the drain. Turns out the tank has a hole in it. You would think these things would last longer than 27 years. LOL.
    Paul
  5. #5
    alany's Avatar
    Join Date
    Feb 2007
    Hertfordshire UK
    Posts
    109
    My Gallery
    try applying some heat to the joint, that is the way we would do it on an an industrial sized air receiver.
    Alan Y
  6. #6
    R.I.P. - 2010/08/27 jdaniels's Avatar
    '05ST1300'02FZ1
    Join Date
    Aug 2007
    Apalachicola,Florida
    Posts
    266
    Tip Overs
    1
    My Gallery
    Use an "easy-out".
  7. #7
    (Threadstarter)
    stoc445's Avatar
    2014 Kawasaki C14
    Join Date
    Jan 2005
    Owasso, Ok.
    Posts
    284
    My Gallery
    Thanks Gentlement, good ideas. I'll post up when I get the sucker out. I did try a 4' breaker bar, but that didn't do it either. I'm thinking a flaming hack saw will probably do the trick...
  8. #8
    GTEdge's Avatar
    '99 ST1100
    Join Date
    Feb 2010
    La Vernia, TX
    Posts
    309
    Tip Overs
    2
    My Gallery
    I'm sure you've tried letting oil penetrates soak over night. Those sometimes help to loosen stuck threads. As for the inside of the tank, I've used the por15 rust preventative paint with success for external surfaces (read vehicle roof). It actually works as advertised. I used a starter/sample kit and finished the job. They also fuel system restoration products that might work for you. http://www.por15.com
  9. #9
    Fireball's Avatar
    2003 ST1100P
    Join Date
    May 2008
    Calaveras County, California
    Posts
    458
    My Gallery
    do not put anything into the tank that you don't want coming out. Oil, rust-killer/converters (acid) etc will not be good for air tools, tires or paint.
    If easy-outs dont work, drill and re-tap, the softer brass will yield allowing restoration of the original threads. Use a tiny bit of anti-sieze or teflon paste when re-assembling
    I don't always have nothing to say, but when I do, I post it on Facebook.
    03 ST1100P slightly used, some assembly required
+ New Posts
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
