Hello guts I will be removing the tank on my 07 st1300 for a CB install, and would like to remove it for ease of wire routing. At what level on the gas gauge would be safe to do so?
Thanks.
Thanks.
I know I need to loose a little weight but you don't have to be rude...Hello guts I will be removing the tank on my 07 st1300 for a CB install, and would like to remove it for ease of wire routing. At what level on the gas gauge would be safe to do so?
Thanks.
sorry about the typo.
Thanks
I just finished up an install in the throttle body area .. Yes you can prop it up , but its easier to take the wiring harness out of the holder clip on the bottom of the tank, remove the retaining wire from the front , and gently pull the front of the tank up and back , hook a bungie cord on the one of the front tank mount holes, NOTE: remove the the metal washers and guides or they WILL fall out , and secure the other end of the bungie cord to the mount the the front of the rear seat locks into . It holds the tank up and out of the way , and you aren't stressing any of the fuel lines or wiring.Need to access the throttle body.Will need to use an impact screwdriver to remove screws from air box.Can this be done safely without removing the petrol tank, or, if i need to move it is it straight forward ?
Any suggestions ??
...niall
