Results 1 to 8 of 8
Thread: When to use Moly grease
  1. #1
    HOPS! Diesel Dave's Avatar
    04 Candy ST1300
    Join Date
    Feb 2010
    Queensland, Australia
    Posts
    271
    My Gallery
    Is there a rule of thumb as when to use Moly grease instead of normal or when NOT to use it?
    Same with white lithium grease?
    Can any of you gurus put the explanation of these greases into words someone unskilled in the industry like me can understand?
    e.g. drive shaft lube is Moly grease - why?
    Ta. Dave
    If you're not living on the edge - you're taking up too much space!
  2. #2
    Be Thou My Vision dduelin's Avatar
    Join Date
    Feb 2006
    Posts
    7,125
    Tip Overs
    08
    2017 Miles
    005775
    My Gallery
    Re: When to use Moly grease
    Moly grease is for high pressure metal sliding against metal situations hence its use on splines and pinion gears. In bearings where there are rollers or balls under the load regular fiber or lithium grease is used.
    Dave
    Honda ST1300
    Honda NC700XD
    Honda CH80
  3. #3
    Unterbrecher von Sachen BakerBoy's Avatar
    2016 R1200RT
    Join Date
    Jan 2008
    Golden, Colorado
    Posts
    7,169
    My SPOT
    My Gallery
    Dave, not a lot of good explanation online. Some info can be found here:
    [ame="http://en.wikipedia.org/wiki/Molybdenum_disulfide"]Molybdenum disulfide - Wikipedia, the free encyclopedia@@AMEPARAM@@/wiki/File:MoS2chips.jpg" class="image" title="Molybdenum disulfide"><img alt="" src="http://upload.wikimedia.org/wikipedia/commons/thumb/0/0b/MoS2chips.jpg/200px-MoS2chips.jpg"@@AMEPARAM@@commons/thumb/0/0b/MoS2chips.jpg/200px-MoS2chips.jpg
    http://en.wikipedia.org/wiki/Lithium-based_grease
    http://www.allthingsmoto.com/forums/...question-4282/
    FYI, some dealers & mechanics assume that moly assembly lube (having only a few % moly disulfied, and a low temperature carrier 'grease') is equivalent to moly paste. Not true. Moly paste does not lose any appreciable amount of it's properties up to maybe 600 deg F because of both the moly disulfide properties and its relatively low fraction of the carrier 'grease'. Lithium doesn't provide the same properties as moly...it is has a lower temperature and lower load rating, and generally degrades quicker IIRC.
    There is a difference between a CV joint (like splines) and a roller bearing. Specifically a CV joint or spline does not have flow or relative movement of parts, but a bearing does. In a spline, the same mating surfaces always stay together. In a bearing, the balls & races move relative to each other and there is continuous flow and blending of lubricant and air. So a little grease haphazardly applied in a bearing gets spread to the friction surfaces. But in a spline the initial lubrication of each mating surface is all that the mating surface ever sees. Hence, the flowing properties of the grease or paste matters--when using a paste it is assumed that it is properly lubricated on every friction surface during assembly, and that the lubrication (paste) stays in place during the entire service life.
    So, no simple / clear answer.
    My summary
    John - 2016 BMW R1200RT
    "Sometimes you find yourself in the middle of nowhere,
    and sometimes in the middle of nowhere, you find yourself." ~Unknown
  4. #4
    Natural Rider Enhancement Blrfl's Avatar
    Fast Blue One
    Join Date
    Aug 2005
    Northern Virginia
    Posts
    10,516
    Tip Overs
    1
    My Gallery
    (Everybody beat me to it, but here's more...)
    Quote Originally Posted by Schmoop View Post
    The rule of thumb is that you use whatever kind of grease is called for in the assembly diagram in the service manual. Anything requiring grease will have a symbol that looks like a grease gun with one of the following in it:
    • GREASE - Multi-purpose lithium-based grease
    • M -Molybdenum disulfide grease with at least 3% moly content
    • MP - Molybdenum disulfide paste with at least 40% moly content
    • S - Silicone grease
    These are all described in the front of the service manual, just behind the table of contents.
    Grease is a lot like paint: there are different formulations for different applications. For example, the latex paint you use on the walls of your living room would look very nice on the hull of your boat but wouldn't last an hour once you put it in the water. For boats, they have special epoxy paints that would look hideous in your living room.
    Multi-purpose grease is called for on sliding surfaces like axles. Moly grease and paste are used when the surfaces are under pressure; which you use depends on how much. You'll find silicone grease on the disc brake pins and the clutch master cylinder piston because it won't destroy the rubber boots that cover them.
    Needless to say, they're not interchangeable. If you put a general-purpose grease on the rear wheel or drive splines, the pressure will destroy it, the splines will have no lubrication and will wear out. Similarly, moly paste is very thick and gloppy and probably wouldn't do a good job keeping itself nicely spread out on a sliding surface like an axle.
    HTH.
    --Mark
    Wizzzzzzzzzzzz What's a Blrfl? ... Shameless plugs: STWiki
  5. #5
    Imported Viking Tor's Avatar
    2015 BMW R1200 GSA
    Join Date
    Apr 2005
    SC Pee Dee
    Posts
    1,913
    My Gallery
    To sum it up,,,if the service manual calls for Molybdenum Paste (rear wheel splines comes to mind) that's what you need to use, not some off the wall marine grease some dealers use.......on splines. I bought my jug here. 70% instead of 60%, but still good
    2015 BMW R1200 GSA
    "Adventure Is Just Bad Planning" - Roald Amundsen
  6. #6
    Your Humble Scribe Bones's Avatar
    2014 BMW R1200RT
    Join Date
    Dec 2004
    western Mass
    Posts
    7,334
    2017 Miles
    000480
    My Gallery
    When to use Moly grease? When she squeaks.
    Ride. Good.
    ___________________________
    Reading material: MotoBones.com
  7. #7
    1100 degrees is hot juddspaintballs's Avatar
    ST1100 SSMST
    Join Date
    Nov 2007
    Union Bridge, MD
    Posts
    885
    Tip Overs
    2
    My Gallery
    I lightly moly anything that looks like it needs lubrication with Honda moly, except for packing bearings. My SSMST is among some of the oldest STs on the site and it hasn't fallen apart yet using that rule of thumb. YMMV, but don't overcomplicate things.
    Jed Gregory
    1991 ST1100 40 amp SSMST "STella"
    In my line of work I meet a lot of people by accident.
  8. #8
    2015 BMW R1200 GSA
    Join Date
    Apr 2005
    SC Pee Dee
    Posts
    1,913
    My Gallery
    Quote Originally Posted by Bones View Post
    Might be a little on the late side by then.......
+ New Posts
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
