Please- pics if possible and definitely a review of your install experience. I'm this -><-close to ordering the Mirror kit first. I should've busted a move during the summer.I just ordered the air deflector kit
I'll probably use a hair dryer. Less heat and more asbestos!SupraSabre said:Also, it wouldn't hurt if you warm them up with a heat gun before installing!
I would think so, since the cop bikes, I've seen, come with the deflectors on them!Can the mirror deflectors be used with the Honda police light mounts?
Login needed.Maybe not across the board.....
Ok that front tip over guard (chromed steel loop) fastens at the bottom to the lower frame. What does the top attachment point bolt to? The engine? Is there some special bracket inside the fairing that goes to the upper frame?
Okay, but it does have the lower air deflector on it...
LOL! I thought about putting on a 200W box and speaker for the air horn. 300W with the air deflectors?KneeDrachen said:Main lower air deflector puts out 100 watts of wails and yelps
So, do the lower air deflectors act as noise deflectors (from those wails and yelps) also?...Main lower air deflector puts out 100 watts of wails and yelps
You're probably out of luck there. I don't think they were ever popular enough to warrant any mass production. You can try a wanted post, you might get lucky.Mellow:
I am at my wits end trying to source a source a set of rear fender valances for my 05 ST1300.. Don't know if you have ever seen these but several yrs ago I saw a pic of a European or GB bike with these. They fill in some of the area when the bags are off and look real good...turns the ST into a sportbike.
I also posted a query in "Wanted" but thought I would ping you also.
Thanks,
Dick T
No, you don't have to order a complete set.... Just pick on any of the ST1300P and go to lower cowl. You can get any piece you want! For the mirror deflectors, that's a different story...I haven't found them yet.Those push pins are trash.Lost my left cowl and deflector lid today. Ordering up the lid is OK but I am afraid the deflectors of course only come as a complete set and I only need the left lid cover piece.
