Smartire Sensor...SOLVED! My rear Smartire sensor was showing signs of old age. It was very slow to register at any speed and sometimes wouldn't. Time for a new one...but where. They weren't being made anymore and Vulcan Tire was no help. I Googled Smartire sensors and Bob Dickman Tire showed up.
http://dickmantires.com/SmarTire/Stire_sensors_tools.html
I called 800 257-8430 and talked to a Paul Kintigh about the green unit Part # 200.0171. He didn't have any experience with the motorcycle version of Smartire, but he assured me the sensor would work in cars. I bit the bullet for $94.70 ($89.50 for the unit and $5.20 shipping). Paul included the high cradle for free just because we didn't know what was needed. (Low is what you need for a ST) It came soon enough and was well packaged. Don't worry that the Part # in the picture on the website (200.0171) is different from the invoice Part #(201.0017) that comes with the part. The light green color is the important part. The install was a simple swap out of the old grey unit. Balance the wheel naked (?) by sliding the unit around in the general area of opposite the valve stem. As you can see from the picture, the low cradle fit well and should be no problem on the slightly larger radius front.
Paul advised to use the deflation method rather than shaking the unit to activate it. What this means is to pump it up to 42 psi, then deflate totally, them pump her back up. What this does is flip the switch (metaphorically) from totally off from the factory to on and broadcasting every 15 minutes. This last part is different from the grey units which broadcast after 6 mph and goes off when stopped. For those that have lost or can't find their old motorcycle version manual, you can find a downloadable version on the Smartire.com website under Support - 'older manuals'. I was worried when, after putting the receiver in 'learning mode' or CP, it didn't register. After a few minutes, the number came up and it went to the two small blocks indicating registration front and back. What had happened is that I'd just caught it somewhere in the 15 minute cycle when I started driving. After it registered with the receiver, it did just what you'd expect...pressure...plus/minus what it should be...temperature...front and back. Everything works just as it has been for the past six years and I'm a happy camper. For those who are concerned that it never really goes off...well, just don't worry about it. The new unit should last as long or longer than the old grey ones...I hope!
Edit: The price quoited above is wrong...in a good way! The price for the light green unit is $85.37 not $89.50. Hey it's barely a gallon of gas, on the other hand, it is better than a sharp stick in the eye! The price does include a cradle and I highly, highly recommend choosing the low cradle. I was also slightly wrong about it's transmitting. Unlike the grey sensor, the green unit doesn't truly turn off when at rest, but it does slumber so it is not transmitting every 15 minutes all night long. The longevity should be the same or longer because the new units have a bigger battery. Paul indicated that the units are now being manufactured by Bendix and that he just got 50 in house, so I doubt there will be any need for hoarding. Still, why is a tire dealership in a small Oregon city the only source that pops up on Google? Maybe it's the same as when Vulcan Tire used to be the source for the Smartire stuff. Maybe Two Brothers might pick up on this so we would have a secure source into the future with a motorcycle tire background.
