Mellow has already figured all that out and has kindly posted it so we don't have to. ST1300 - Switched Power Tap.Where did you grab the switched power for the relay...
+1 on the Oxford heated grips with 5 heat settings and auto shut off if voltage gets low, $80.oo.Does anyone know if BMW heated grips (the complete grip with the OEM BMW heating element not just the rubber) will fit on an ST1300? Are the throttle cable hook
I installed a set of Oxford heated grips on mine last month. $89.00 and very simple to install. And boy do they work good! I ordered mine from Revzilla.
I even have extra thick Grip Buddies over the grips, still very Hot.
Yes. Or if they are not, the difference is insignificant.Are the BMW grips the same length as the Honda grips?
