Symtech Heaters and BMW Grips anyone?
Dave.David
Rider
SB California USA
05,ST1300-04VTX1800R
8938
Does anyone know if BMW heated grips (the complete grip with the OEM BMW heating element not just the rubber) will fit on an ST1300? Are the throttle cable hook
I installed a set of Oxford heated grips on mine last month. $89.00 and very simple to install. And boy do they work good! I ordered mine from Revzilla.
+1 on the Oxford heated grips with 5 heat settings and auto shut off if voltage gets low, $80.oo.
I even have extra thick Grip Buddies over the grips, still very Hot.
drrod
Calgary, Alberta
'04 ST1300
8313
Are the BMW grips the same length as the Honda grips?
Yes. Or if they are not, the difference is insignificant.
BTW - I ran Symtec heaters under the BMW grips on my last ST with no issue. Wired them through a fuse block. Mounted the 2 position rocker switch on the flat area just behind the glove box lid on the left side.
