Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: How does the power windscreen mechanism work??
  1. #1
    sennister's Avatar
    '93 ST1100
    Join Date
    Aug 2007
    Grant, MN (aka Stillwater)
    Posts
    5,897
    Tip Overs
    1
    My Gallery
    I guess this is a question to those that have tore into them. A while back I recall reading about someone who was looking into replacing the plastic gears with metal ones. That seemed to have died off so I assume it has been determined to be too complex or the needed resources were not available. Over the weekend I was thinking about this and something crossed my mind. I think most efforts have been at reverse engineering a poor design to reproduce it with stronger components. A problem with this is the components that were being looked at were failed components. Another approach to this problem would be to redesign rather than reverse engineer. What if we redesigned how it worked with a better drive?
    What I am looking for is come more information at this point as to how it works. I think there are cables that are attached to the movable parts now. These cables could possibly be reused or if needed replaced to relocate some components. This is what I am focusing on at this point. Can the cables be removed at the motor side and be driven by something else? Also what is the current range of motion of the windscreen. Since mine is shot, I can't move it anymore to determine this. I know that currently it is limited by relays or switches. This was done in an effort to prevent the plastic gears from stripping. I guess it didn't work
    This weekend I was sitting in a deerstand with lots of time on my hands to think about this problem. This is when I got the idea to redesign rather than reverse engineer. I was thinking about the possibility of replacing the motor and gear box with a lineal actuator perhaps something like this. Link to spec sheet This was the first one that I came across that might work in this application. It is available in 2", 4", 6", 8"+ range of motion. It is a screw drive so it could be reversed at any point. It supports a static load of 500lbs and a push pull load of 110lbs, 25% duty cycle with a .5"/sec speed. I haven't looked at what the current range of motion is of the windscreen to see which would be the best model yet. While it may be possible to retain the current circuitry that limits the range of motion now, we still don't want too big of a unit in there. I think the issue Honda was trying to engineer a way around was having too big of an assembly. For instance in order to get 4" of travel the actuator ranges in size from 9 3/4" to 13 3/4". This is pretty big and may mean that the actuator may need to be relocated. The nice thing is that since I think this is currently cable driven we might be able to relocate it pretty easily. We have lots of plastic to hide this under. We just need to find a place for it. Honda probably wanted to keep the assembly as small as possible so that explains why they designed it as they did. It doesn't give them an excuse for plastic gears though.
    So what do you think? I'll bet we can come up with a better design for this thing using off the shelf components.
    STOC# 6145
    IBA# 53268
    1993 ST1100 non-ABS
    2003 ST1300 ABS (RIP)
    Too many Farkles to list. Take a look at bike mods in my profile.
  2. #2
    (Threadstarter)
    sennister's Avatar
    '93 ST1100
    Join Date
    Aug 2007
    Posts
    5,897
    Tip Overs
    1
    My Gallery
    Re: How does the power windscreen mechanism work??
    I did some searches it looks like the range of motion might be 7.4". So to retain full motion we would have to go with the 8" working off the Honda limiters. Of course someone might point out that the windscreen changes angles as well as height. I am aware of this but it is accomplished by the track design and since this would remain intact that would not change.
  3. #3
    Anna'sDad's Avatar
    '06 ST1300A
    Join Date
    Nov 2009
    North Plainfield, NJ
    Posts
    441
    My Gallery
    Looks like AzDesertRider encountered the same problem just about 2 years ago.
    Check out this post, thread No. 16 has the photos.
  4. #4
    Site Supporter Uncle Phil's Avatar
    ST1100(s)
    Join Date
    Feb 2007
    Nashville, Tennessee
    Posts
    6,661
    2017 Miles
    012716
    My SPOT
    My Gallery
    SENNISTER - The problem maybe with the unit's total length if you go for the 7" range. It looks like 413mm ~ 16 1/4 inches - pretty long for the space available (if I read the specs correctly). I've been looking for something similiar for a power windshield 'driver' for the ST1100 but no joy yet. You might look at automotive power window motors that use a cable to do the up and down.
    97 ST1100 STD +150,000 / 02 ST1100 ABS +114,000/ 97 ST1100 ABS +75,000
    www.UnclePhil.us
    "There's more to leading than being in front." - Uncle Phil
  5. #5
    Ventura Highway wjbertrand's Avatar
    Join Date
    Feb 2005
    Ventura, CA
    Posts
    4,715
    My Gallery
    There have to be hundreds of cage electric window motor assemblies out there that could be adapted. Last one I looked at didn't look any more robust than the one in our STs though. All plastic mechanicals and plastic tape/cable.
  6. #6
    (Threadstarter)
    sennister's Avatar
    '93 ST1100
    Join Date
    Aug 2007
    Posts
    5,897
    Tip Overs
    1
    My Gallery
    Quote Originally Posted by Anna'sDad View Post
    Sweet!!! That is what I was looking for!!!. Thanks!
    From looking at these photos, I see why no one was able to come up with a new set of gears at this point.
    That gear is going to be tough to make. Not impossible but it will take some specialized tools. I have some but not all of what would be needed. The other problem is that the labor involved would be pretty extreme. It also doesn't help if the cable is worn because it is the other half of the gear. Based on how mine is failing it is likely one of the teeth in the gear on the motor. If they only sold that part. I suspect that the cables are fine in my case.
  7. #7
    (Threadstarter)
    sennister's Avatar
    '93 ST1100
    Join Date
    Aug 2007
    Posts
    5,897
    Tip Overs
    1
    My Gallery
    Quote Originally Posted by Uncle Phil View Post
    Yeah. I am aware overall length is likely going to be an issue. Like I mentioned. I think the reason they went with this design is to reduce the size of the assembly the good thing is that we have lots of plastic to cover up an ugly linear actuator. Since it looks to be cable driven as I thought. It might be possible to extend the cables and install the actuator where we have room to hide it. Of course this spot would have to be verified on both the ABS and non ABS bike. Plus there is the chance that someone has a farkle taking up the space. There are other types of options here as well. The car power window drive for instance is another good option. It is very possible that Honda lifted what they are using in this application from something else. I wonder what the power window assembly looks like on a Honda Civic
  8. #8
    ST1100(s)
    Join Date
    Feb 2007
    Posts
    6,661
    2017 Miles
    012716
    My SPOT
    My Gallery
    SENNISTER - There's a particular power window assembly that hot rodders are find of but I can't remember what model. It is supposed to hold up well and be adaptable. I'll have to prowl around in my windshield notes when I get home. I do have a very nice adjustable windshield prototype from MadStad Engineering on one of my ST1100s now. I hope that he will make it a production product for those that are interested.
  9. #9
    (Threadstarter)
    sennister's Avatar
    '93 ST1100
    Join Date
    Aug 2007
    Posts
    5,897
    Tip Overs
    1
    My Gallery
    Are you thinking of this?
    EL1000
    Though it is a little spendy, it is still cheaper than a new assembly. If it gets better life it might be a good option.
  10. #10
    Just Chillin'! sirepair's Avatar
    93 ST1100
    Join Date
    Jun 2007
    Chillicothe, Ohio
    Posts
    3,571
    Tip Overs
    3
    My SPOT
    My Gallery
    I think the cable operated power window regulator, like this one, could be adapted pretty easily. I may see what I can come up with over the winter. This one is used on chevy pickups/suburban/tahoe etc. Readily available. $45.00
    It's S-I-Repair! Pat O STOC# 7105 IBA# 37880 There's no dumbass vaccine! 15 Yamaha FJ09 "Thorn" (another fast, red one!) 93 ST1100 "Suzaku" C.G. Red (you know, the fast color!) 84 VF500F Original Owner! 89 NX250 (will live again!)
    This week I achieved unprecedented amounts of unverifiable levels of productivity...
+ New Posts
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
