Bridgestone BT023 for ST1100
Kingman, Arizona
2000 ST1100 ABS TCS
004
Guys, I suggest you take yur tar questions to Tim at Keel Brothers Tires. Tim has done very good by me.
Uncle Phil
4 ST1100(s)
002064
698
BART - If you ate up a Z6 in 4,000 miles, I'm gonna be in trouble too! BTW, I already have a modified Harbor Freight Tire changer - and I've got my moneys worth out of it a long time ago! I looked at a Coats 220 (high quality manual changer), but they are little bit pricey - $1,400+ delivered. NoMar appears to be the next best step, around $650 for what I need. Good quality air-powered changing machines are way up there from what I've seen.
970mike
Mike Brown
Lompoc, California
07 & 12 ST1300A
SPOT
LINK
8057
That's the one I am thinking of. After just getting charged $90 to mount and balance two tires, It is time to invest in a tire changer.
It has more then payed for itself in a very short time. It helps to go in with someone to save you even more. Good luck and post up if you get one.
DaveM
Wilton, NH
2021 BMW 1250GS
7806
Bringing up from the dead...sorry
So what is the recommended tire for an 2000 ST1100A? The 023s or?
You are going to get 10 different answers....LOL!!
I go with the BT020's , I have a '99 ABS.
sent from my Droid phone.
Benton, AR
1991 ST1100
7908
I have run 2 sets of Storms and 2 sets of BT023s. got 11k and 8K out of the rear Storms, 14K out of the Storm fronts but bike shook like a belly dancer on speed. 8K out of the BT023 rear and the other is new. Around 8 or 9K out of the BT023 front and that's OK. Tired of the front lasting 2 rears as that way you are running on a 1/2 worn out front with a new rear. gvie me a fresh set. Ran a BT020 bias rear with a BT023 front, with me changing the rear at 14K with some left, but the bias rear is the only tire that I have had lock and slide with the rear brakes on dry pavement and resulting in 2 crashes. I guess BT023 for me.
