Home
Go Back   ST-Owners.com Forums > ST Forums > Farkles > Horns / Mirrors
Reply
Thread Tools
Old 07-09-2005, 07:51 PM   #1
CrashTestDanny
formerly known as danf
Bike: 2005 ST-1300
Tip Overs: 3
Farklin the horn
Hey guys - the postman left my Stebel TM80/2 139 Db horn set while I was out riding today and we are both (me and the bike) very excited to get it installed! But since Helm doesn't have the manual in print at the moment and my local Honda dealers seem to be unable to sell me one - can someone give me a brief run-down on how to get the sides panels of the front fairing off?
Thanks!
Thank you Jesus, I'm alive!!! (11/21/2005)
Dan - '05 ST1300 - resurrected!
CrashTestDanny is offline CrashTestDanny's Album  Reply With Quote
Old 07-09-2005, 10:52 PM   #2
crinteastwood
Flatlands of Canada
crinteastwood's Avatar
Dan - the horn is accessed by removing the inner panel of the fairing - its on the right side of the bike - one phillips head screw and 4 or 5 push rivets - pull the head out on these and then pull the whole rivet completely out. there are also 2 rivets on the inside plastic (close to the frame) just on the outside of the right hand glove box. - these have a pin that must be pushed inwards and then pull the rivet out - its simpler than it sounds. Lastly, remove the panel from the front of the bike beside the front wheel assy. nb - there is a phillips head screw holding the outside temp sensor to this fairing piece as well - you will see it when you pull the panel out.
Mick
Sticks and stones may break your bones.but so would an 80lb carrot.
crinteastwood is offline crinteastwood's Album  Reply With Quote
Old 07-10-2005, 06:04 PM   #3
CrashTestDanny
Bike: 2005 ST-1300
Tip Overs: 3
Mick
Thanks for the info, Mick. I decided to pull the right outer fairing panel instead since I needed to stuff some rather large horns in place of the stock one. I have some pictures for you guys - the fit is actually very comfortable and even has a good bit of clearance below the right side storage compartment.
I haven't decided where to pull power from yet. The two horns together are supposed to draw 12A total and the stock fuse is 15A, so I was considering running them in parallel on the stock circuit. Anyone wanna talk me out of that? If so, how would you recommend that I get power to them?
Click image for larger version
ID:	2655 Click image for larger version
ID:	2656 Click image for larger version
Old 07-10-2005, 06:23 PM   #4
tinfish81
tinfish81's Avatar
Check out the following thread...some very useful info on powering your horn and why you should use a relay:
http://www.st-owners.com/forums/show...ghlight=stebel
tinfish81 is offline tinfish81's Album  Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright 2004 - 2010 ST-Owners, LLC (All rights reserved)
Sponsored Links
