Greetings ST1100 owners - can anyone provide the left and ride side fork spring spacer/preload collar measurements for an OEM '96 ST1100? Length is the one I need most, internal and external diameter would be helpful as well. More details for those interested:
I am currently in the process of rescuing a 1996 ST1100 (Non-ABS). The bike has about 70,000 miles on it, and narrowly avoided the scrapyard after the prior owner attempted to turn it into a 'cafe racer' of sorts without much success. The rear suspension was completely dead, so I ordered a replacement from Hyperpro along with a set of new fork springs. Upon disassembly of the forks, I discovered the springs inside appear to have been replaced with springs significantly longer than OEM or the Hyperpro replacements, measuring ~431mm. The right side fork lacks a preload spacer entirely, while the left side spacer is crudely cut from thin-wall tube and is shorter than OEM at ~82mm. There was very little preload compression when I disassembled, maybe a quarter inch or so tops. The fork oil was absolutely rank and very dirty, so they've been in there a while. Adding to the confusion, the new Hyperpro replacements measure around ~393mm, shorter than the 415.6mm quoted for OEM in the Clymer manual I have.
At this point I'm a little stuck on how to proceed. I was able to find an OEM right spring collar (Part#51402-MS2-003), but the left side collar (Part#51402-MT3-611) was unavailable. If anyone can provide the correct measurement for that part I'd be greatful. The documentation that came with the Hyperpro says to use the 'standard' spacer @ 130mm for left, 50mm for right. Furthermore, as this particular bike is going to end up substantially lighter than stock given how much of it is missing, I suspect I'll need to shorten each spacer anyway to decrease preload to get the suspension dynamics right. That will likely require some experimentation, so I'm planning to start full size and trim them as needed. If anyone has suggestions for how much to trim them buy per reduced weight, that would also be helpful information.
Additionally, the Clymer manual calls for Honda SS-7 suspension fluid which as far as I can tell is 5w? While the fluid Hyperpro provided with their kit is SAE 20. I'm unsure on what weight fork oil I should really be using here, especially with the bike being dozens of lbs lighter.
Thanks!
Current springs (both sides): ~431mm
Current left spacer: ~82mm
Spring free length quoted in Clymer manual: ~415.6mm
Hyperpro springs (both sides): ~393mm
Hyperpro left spacer measurement: 130mm
Hyperpro right spacer measurement: 50mm
Thanks!
