Another dilemma on my carb rebuild. So got the carb back together, then installed. Went to sync her up using my flow meter and found that #1 was only reading 1000 no matter which direction I turned the #1 sync screw. If I hit the throttle it then shoots up, but then back to 1000. I then removed the carbs, tore #1 down with the exception of the air shut off valve (as I would have to completely take the carbs apart). All looked good......put back together, reinstalled. Started her up, and still at 1000. Thats where I'm at now. Any suggestions? As always, any and all help is most appreciated.
