Well I pulled the trigger (so to speak) by buying my 1st touring ... an ST1100, 1994, with 20k.
After my 1st short 1 hour ride I parked it and couldn't wait to start it up and go for the next run. Next day went to start and it wouldn't start, apparently the seller rigged the incorrect battery, so I bought the right one and installed, problem and repaired.
Started her up and 3 minutes later fuel everywhere, well fuel leaks are usually cut and dry to find, repair sometimes can be a surprise, but I removed the air box, found the bent clamp at the fuel line and fixed.
Getting back together was a little of a surprise. Those rubber snorkels and getting them seated and the airbox base aligned at the same time proved to be a challenge. Any secrets/tricks/ to that?
Next surprise was when I was reconnecting all vaccum and breather lines. I have one extra, can't find where it connects and my fear is that I missed a connection under the airbox between the carbs. I have posted a pic. Any input please?
Thanks ahead of time for any answers.
