Removing the throttle body insulator clamps to replace the fuel injector sub harness. Each cylinder has an upper and lower clamp. Is it only necessary to loosen the upper clamp on each of the cylinders to remove the TB ? I think I was initially looking at it incorrectly thinking I had to remove both the upper and lower clamps.
i was able to easily loosen the clamps on cylinders 3 and 4 from the side underneath the main frame rail but cylinders 1 and 2 appear harder to reach and are set pointing straight back to the rear of the bike. I found an old thread that mentioned using either a 16" or 20" #2 phillips so I'll have to take another look at it and see if there is a position I can get it from. Love to find out it's that easy vs. trying to concoct something crazy with all my 1/4" drive fittings and a JIS head. I currently have a set of regular length JIS screwdrivers but nothing nearly that long. I am waiting on an order of 1/4" JIS bits if I have to get a lot more creative. I've also lubed up the neck of the insulators with PB Blaster in advance to help make the TB removal easier.
Appreciate any suggestions from those that have dug in here before. Thanks.
